Question about Peavey CS 1400 Amplifier
Peavey amp on my peavey cs400 amp it has two binding post outputs for speakers which says 28v rms, am i able to connect my speakers here without damaging them?
    Genius:
  • 1,175 Answers
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
http://www.peavey.com/assets/literature/manuals/80300990.pdf
Posted on Feb 16, 2009
    New Friend:
  • 59 Answers
Yes, as long as the speakers are rated 400w+& 4-8 ohms each and you don't overdrive them.
Posted on Dec 05, 2008
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: peavey cs400 amp
Hi...
That 28V RMS means how many RMS volts max comes out of the speaker terminals.
As long as your speakers can handle a couple hundred watts , youre fine.
Posted on Mar 01, 2009
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Apr 23, 2017 | Car Audio & Video
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
I have 2 peavey 900 Power Amplifiers i would like to link them together was wondering what is the input wattage it can handle?? not wanting to mess anything up!
You CANNOT link the outputs of the amps. They need to drive seperate speakers.
You can tie the inputs together so they will send the same sound to their seperate speakers.
Max power for the Peavey 900 is 900 Watts RMS into a 4 ohm speaker in Bridge mode... That is enough to blow many speakers.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
I want to run an additional amplifier from my 5.1 surround system amp speaker output to drive large dj speakers. The dj speakers need 175 rms and my 5.1 only has 100 rms per channel. Can I just wire from...
Speaker output from the amplifier is a higher voltage than a preout. The speaker level signal has to be reduced to a line level signal in order to connect to another amplifier. I used a car stereo "speaker to line level adapter" and then connected a second amp to run my front channel speakers. Works just fine.
Dec 15, 2009 | Sony STR-DG500 System
PV 2600, couple years old, light usage. Connected to two PV SP3K speakers. One channel started to cutout somewhat but not all the way, Switched a few input cables, swapped L&R. Then whole amp shutdown....
Hi..
I've worked on similar units.
Things I'd check first :
Dust in the unit.
Weak solder connections /crusty debris stuff on the input jacks or output terminals
Any flex cables soldered in tend to be a problem on peavey amps I resolder all those contacts.
Checking the amp w/o a load IS NOT a good suggestion.
What style output connections are you using?
1/4 inch, binding post, or Neutrik style?
Dec 29, 2008 | Peavey PV® 2600 2-Channel Amplifier
Peavey cs400 amp
Hi...
Dec 05, 2008 | Peavey CS 1400 Amplifier
753 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
