Question about Dell Latitude D600 Notebook
Laptop Display flashs then screen locks up
If running a video for awhile the screen colors start to fade, screen locks up and requires a HARD shut down and reboot
  • 4 more comments
  • soliver871 Dec 07, 2008
    thanks
    thanks for
    Thanks for the above information... it doesn't seem to occur when docked to my docking station and using external monitor. My IT dept. is suspecting something is going on with either Video card or motherboard... Laptop os only a little over a year old. I had a complete video blank issue about six months ago and hand to open up behind key board to reset video cable which fixed issue. Under warranty still so if continues will have Dell come to my company to fix for certain... Again thanks for the feedback R/soliver871
  • sachmo499 May 11, 2010
    FRCS68 is right. try an external monitor. If that doesn't work you have a motherboard issue. If it DOES work you have a laptop monitor problem.
  • Joe May 11, 2010
    How old is it and how long has it been since it was opened up and cleaned?
  • Frank
    Frank May 11, 2010
    try an external monitor, if you have one,
    that will tell you either is the monitor or the laptop main board is having a problem.
    I suspect the motherboard.
  • 81 Answers
I wouldn't suspect its anything other than your lcd or inverter. Connecting it to an external monitor cements it. If it was the video card or motherboard it would have certainly done it again. For it to appear locked up would just mean the picture you are watching was the last in its memory to post. Meaning, if the inverter or lcd start having problems, the last thing it was told to display would appear to be frozen to whoever is watching but in actuality its the display not machine that is frozen. Try ejecting the cd tray. Better yet set your power button shut down when pushed. Then have it have another lock up watching a video then push the power button or eject to see if it responds. Then you will know forsure. Hope that helps.
Posted on Jan 04, 2009
DELL e5510: suddenly whenever I turn on my laptop it will just flash with lines that looks likes threads of clothes? then after a few seconds the screen is just black and full of colored vertical lines (...
Here is a hardware test you can run to test the video and lcd screen. That came with your laptop
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will BEEP ! it is asking you if colored bars are displayed. if the bars look ok then your screen is fine but if during anytime of this test and you see the distortion you described then its the LCD screen or LCD cable
hope that helps
Sep 07, 2013 | Dell Latitude E5510 Notebook PC
Lock A and Lock 1 flashes at start up no display then shuts off
Let's go back in the diagnosis
You checked with an external monitor, to see that the graphics chipset was the problem, correct?
When using the Display Assembly from the 6530b on the 6730b, were you able to use the 6530b's Video Cable, to check it out also?
You are FOLLOWING Anti-Static Precautions?
How did the original problem come about?
Makes a difference.
Display just quit one day, or was there damage; such as dropping of the laptop?
Is the motherboard from a reputable dealer, or is it from a major auction house that starts with an E?
Post back in a Comment
Would appreciate all questions answered. I asked each one for a specific reason.
Regards,
joecoolvette
Mar 07, 2013 | HP Business Notebook 6530b
On but no display
So the power is on but there is no display. Does it look like the laptop booted all the way? Does it look like the laptop is running but there is no display?
If the laptop is running, you hear the fans running, the hard drive running, etc. but the display is black, try the steps below:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card is bad.
Apr 07, 2012 | Computers & Internet
My dell inspiron e1505 would simply crash and show a black screen whenever I run a video online on fullscreen. It would stop responding to anything and I would have to force shutdown and then restart and...
Try running the LCD Bist Diagnostics. Press and hold the key while powering the system on. This will start the Preboot System Assessment (PSA) diagnostics which includes a test for the LCD.
In the process of running the PSA, if the graphics test error (0334 or 0333) is given and the user presses "Y" to continue testing, the LCD BIST will begin. During the LCD BIST, a solid color screen is shown and 5 different colors are displayed. While the colors are displayed, the system beeps every two seconds and the lock lights (Num Lock, Caps Lock, and Scroll Lock) illuminate to indicate that the test is running. This can be used to determine if something is wrong with the display.
While running this test, the LCD is operating on its own, free of the video controller which may be discrete (a video card) or onboard (on the system board). The test allows you to tell an LCD panel problem from a problem with the controller. If the colors are displayed across the screen without a problem then the issue lies outside of the LCD.
Aug 05, 2011 | Dell Inspiron E1505 Notebook
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
HP Pavilion Laptop Screen
Bearing in mind you mention the viability of cost, I'm thinking your laptop is out of warranty. This does sound like a pretty major problem, one which HP need to look at. You can always approach them for a quote first, with a min/max price, before you decide whether to go ahead or not.
May 27, 2008 | HP Pavilion dv8000z Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Dell Latitude D600 Notebook Logo
195 people viewed this question
Alun Cox
