-   I get F61 also on SA HT740. But each time I hook up speakers to unit the center speaker burns up. I hooked up speakers because someone said this may be reason for F61 code. Someone also said it may be a defective amp switch. The unit never remains on after pushing power switch, just momentary on, screen shows F61, then shuts down.-   noboatfey
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
The error code F61 it mean the power regulator are missing such as 5V or 12V + --
Are you Tech usualy the electrolytics capacitor dry out, regulator IC defect or over heat in power supply section You can see the layout on those connector mark the voltage like 5VBU 12V+ 12-- then see which one is miss or lower then it should be
Let me know if you need schematic or further assistant
Was this helpful?
Yes
No
Popular Solutions for Panasonic SC-AK17 Shelf System
Bought the unit used. when you turn it on it is in CD mode, the drawer comes open and says remove...
(More)
Bought the unit used. when you turn it on it is in CD mode, the drawer comes open and says remove disc even if there is no disc in tray. It is stuck in cd mode. It acts like it is changing discs but doesn't. Help. By the way it is a 5 disc SA-ak17. Thanks.
following a power outage the system came on automatically and will now not turn off. Otherwise works...
(More)
following a power outage the system came on automatically and will now not turn off. Otherwise works well but it has to be disconnected from power to get it to stop playing We do not have a manual written in English language so cannot correct this problem. spanish manual is written for SC-AK27 and SC-AK 17
A few months ago I could not get any sound on cds, recently I could no longer get sound on the...
(More)
A few months ago I could not get any sound on cds, recently I could no longer get sound on the tuner. Everything else, lights, etc., seem normal..
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
