Question about Intel DG31PR Motherboard
No power do anything
I have the dg31pr mother board the on green led is on that is on the board but i get no power to anything when i cilck the power bottom
  • gjayakanthan Jan 05, 2009
    no power in DG31PR
    Genius:
  • 1,061 Answers
CHECK MANUAL TO MAKE SURE EVERYTHING IS PLUGGED IN PROPERLY.RICHARDM69
Posted on Dec 06, 2008
How can i get warranty on intel DG31PR mother board The mother board is not working. I have to replace it. How can i get it. I am giving this from India
if machine is older you might be better off getting a new machine. You could try ebay for used boards but that is a risk also.
Mar 10, 2010 | Intel DG31PR Motherboard
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
DG31PR MOTHER BOARD I BYIED THE LAST 2 YEARS NOW
DG31pr 001
MumBai 0020
Woeking,Mass
069-56981
Don't foget Postageeeeee
Nov 19, 2009 | Intel Computers & Internet
I just purchased the dg31pr and a Intel Dual Core E5300. I installed the CPU and motherboard into the case and it will not start. The green LED lights up but the computer, hard drive, and fan will not...
did u check with the memory card if it okay....try switching it see wat happens!...and it not it the battery on the mother board thats not botting it up!...
Oct 06, 2009 | Intel DG31PR Motherboard
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
DG31PR Problem with extender usb 2.0 in cascade
go into the control panal and looking in the following folders;
device manager, adding new hardware, network and sharing folder,
problems and report.
look trew the sections that apply
looking for any type of marks that should not be there
red, yellow, orange,
green mark okay
rod
Jan 30, 2009 | Intel DG31PR Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Intel DG31PR Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
