Nintendo Super Mario for 64 Logo
Posted on Jun 27, 2012
What buttons do you press to get the star on the finish line of peachs slide
UNlock nokia phone model3600 slide?
Hi, You can unlock a Nokia 3600 SLIDE safer and easier using unlock code. You can get the unlock code for a Nokia 3600 Slide from www.unlock-zone.com/nokia-3600-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR A NOKIA 3600 SLIDE
1 - Switch on your Nokia 3600 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3600 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3600 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3600 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3600 SLIDE
Unlock code for Nokia 2680s -2b
Hi, You can get the unlock code for a Nokia 2680 Slide from http://www.simpleunlocking.com/nokia-2680-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 2680 SLIDE
1 - Switch on your Nokia 2680 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2680 SLIDE.
4 - The Nokia 2680 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2680 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 2680 SLIDE
1helpful
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
1helpful
Locage Code de restriction nokia 3600 slide imie 359306/02/513989/8
Each Nokia 3600 SLIDE mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3600 SLIDE mobile phone at www.mobileunlocksolutions.com.
1helpful
When I pick up the handset, the intercom picks up. How can I set it to automatically go to next available line to make a call?
This programming needs to be done from Ext 10 or 11
Press Feature 00
Press LEFT intercom TWICE
Press RIGHT intercom ONCE
press the 2 digit extension number you want to set up
PRESS ** ( STAR STAR)
then press the lines in the order you want them to be picked up.
When finished:
PRESS ** (STAR, STAR)
PRESS feature 00 to exit programming.
Done
Line 1 of the pro star 816 will only ring on one of our phones and not the other. Line 2 and 3 rings on the seperate phone but not the other one. How can I make all lines ring on both phones?
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
2helpful
I HAVE AN ATT MERLIN 410 SYSTEM.ON ONE OF MY
At the phone slide the T/P switch to "P"
Press ** (star,star)
press the linjes in the order you want to pick them up.
Slide T/P switch to "T"
4helpful
2answers
I can't find the red ? button in peaches castle!!
In order to get the red question mark activated, simply go into the castle and look up. if you have at least 10 stars there will be a bright light shining down and will "warp" you to the location to get it
2answers
Programing Ayava partner - 18d Phone
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
then the order you want the lines to get picked up (if you want to grab line 4 then 3 then 2 then 1, upon going offhook, press "** line 4 line 3 line 2 line 1)
2answers
Super mario 64
in what stage it?? and what kind of Super mario version it is??
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
