Question about Canon PC-735 Copier
Have a Canon PC 735 and it dosn't want to grab paper from tray.
The wheels do not turn to grab the paper.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If the wheels do not rurn then it is either a clutch or board problem.
you may have to take the clutch apart and clean it, also some clutches have a felt pad on them after years they turn into sticky, clean off.
Posted on Dec 05, 2008
Hi - My daughters Canon MP 210 printer stopped pulling paper into the printer. I did not observe any spinning of the paper grab wheel therefore I'm wondering if a drive belt broke or something else is not...
hello there
you need to check the gear that trigger the paper to pull from the tray, if the gear is making a sound when you print then totally you need to open the gear coz it might be disconnected.
Dec 23, 2010 | Canon PIXMA MP210 InkJet Printer
How do i reset my canon PC-D450 laserjet printer after a paper jam?
Just open the cover from where you are putting your toner cartridges and the printer will start self test and will reset from paper jam.After the printer dosn`t find any paper it will try to print your last task.
Nov 09, 2010 | Canon 730i Laser Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My Canon L280 cannot grab the paper loaded. I've looked in the manual and online and don't see any similar problems. The machine seems to work properly except from the fact that it can't grab the paper...
Please make sure that there is nothing inside the paper tray. You can do this by turning the machine upside down and shake it. Also, see if the rollers inside the paper tray is spinning. If the rollers are not spinning then you need to contact your manufacturer to replace the unit.
Nov 24, 2009 | Office Equipment & Supplies
Printer no longer feeds paper from paper tray; I tried cleaning it, it sounds like the printer is trying to grab the paper but it does not grab it.
Remove the paper tray. Use a lint-free cloth dampened with rubbing alcohol (isopropyl) to wipe all around the black "rubberish" wheels right underneath the unit where paper tray goes. I learned that by calling Okidata.
Oct 05, 2009 | OKI C3400n Laser Printer
My Canon PC735 copier turns off after it grabs the paper.
Main lamp is most likely burned out or is shorting.
You can google it and find a replacement bulb. Not too difficult to replace. Remove the top cover and glass. Make sure your hands are very clean or use a clean cloth to handle the new bulb.
May 15, 2009 | Canon PC-735 Copier
Have a Canon F50 Multipass. The alarm light is
Attempt to re-surface any replaceable rollers with a brillo or Scotch Bright pad ONLY if you are unable to locate replacement rollers. This will reduce the life of the rollers further and can permanently render them defective
Any rollers in the paper path and in the tray area(s) should have texture and should not be glossy or completely smooth with the exception of hard-plastic rollers used only as guides.
Apr 28, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PC-735 Copier Logo
253 people viewed this question
old marine
old marine
