Question about HP iPAQ H2210 Pocket PC
My Pocket PC with a 4Gb Sd
Hi there, i got this iPAQ 22xx and I was wondering if it is compatible with an 4Gb SD Card? Thank You for your kind help! Yos
  • 624 Answers
Hi tHEyOs, Well I?ve been poking around and here are the facts I?ve found: -The largest SD memory card HP lists as an accessory is a 2GB card. -The actual specifications sheet states the SD slot supports SD, SDIO and MMC but makes no mention of any size limitation. My suspicion based on my own personal use of HP hand held PCs is that it will probably accommodate your GB SD memory card. In my own personal experience is that the devices list as accessories only those memory cards that were prevalent at the time the PC was released. So even though the HP site only lists 2GB as the largest its only because the larger cards didn?t exist in the marketplace at the time so it really isn?t any kind of indicator. To me the specifications sheet is the ultimate reference and it doesn?t make note of any type of imitation. If you are still apprehensive buy the memory from a mail order house like TigerDirect and tell them you want a 4GB SD module for an HP H2210 PocketPC. If it doesn?t work you can return it for a full credit. If you have any more questions let us know and please don?t forget to rate the posting.
Posted on Feb 11, 2007
My new 4gb sd card does not register on storage display, and does not seem available to use
The official oprating systems of the HX4700, WM2003 and WM5, do not support SDHC card format. Since most 4Gb "SD" cards are in SDHC format (check the label on your card), the file format of your card is likely to be incompatible with the PDA. Get a 2Gb SD card, or go for a Compactflash card for 4Gb to 32Gb of storage space.
Jan 16, 2011 | HP iPAQ HX4700 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Aug 29, 2008 | HP iPAQ H2210 Pocket PC
HP5550 Storage Card
The HP h5550 is a bit old PDA , and it cant recognize it.As i know , there is actually no way to connect it.Sorry.
May 09, 2008 | HP iPAQ H5550 Pocket PC
HC SD card support for pocket pc
Unfortunately, Pocket PC devices with Windows Mobile 2003 OS do not support High Capacity SD (SDHC standard) cards.
However, some companies have created standard SD cards (Not SDHC) with capacities up to 4GB. These, sometimes, not always, work.
I would recommend you to purchase SD cards up to 2GB in size only which is the maximum size the SD standard has defined. If you would like to try the max capacity you can get, you can try some "SD standard extended, but not SDHC" SD cards up to 4GB. If you would like brand names, I could recommend you a few..
Dimitris.
Feb 23, 2008 | LG KU990 Viewty
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Oct 07, 2007 | HP iPAQ HX4700 Pocket PC
HP iPAQ H2210 Pocket PC Logo
152 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
