I have been using an all-in-one HP Color LaserJet 2840 on a Windows Vista computer for several months. Of late, I can no longer use the scan feature at all, HP Director has 'disappeared' and the evidently 'new' HP Solution Centre refuses to run at all. If I try to initial a scan, I either get no response, or I get a message indicating that there is no device... when I try to resolve the issue by checking out on-line forums, it appears the issue is well known at both HP and Microsoft, but no fix has been offered. I emailed a request for assistance to HP but have not had a response yet, other than an automatic email verifying that my concern has been received. Does anyone know of a solution to this issue? I have lost a major functionality in my home office with no scanner available and evidently no resolution. The all-in-one was bought in May and the computer in June, so it is quite a concern to me that I am having such a problem now.
  • Arithemtic Dec 05, 2008
    Here is what I had tried to resolve this issue: I uninstalled all the HP software and reinstalled from the internet the full solutions package for my all-in-one, and that did not resolve the issue. Subsequently, I again uninstalled all the software and drivers and reinstalled from the original CD and that did not resolve the matter either. When I have tried HP's on-line driver checker it says I am using the wrong driver, but I have tried the route of installing one of the alternate drivers and that too failed to resolve the matter. I am still awaiting some response from HP to see if they have a solution. In the meantime, no scanner, and HP Solution Centre just keeps saying "No HP devices have been detected" in spite of the fact that I am printing with the device even as I write this. Why can I print to the device but not scan? IRIS has been my OCR software program, and it says also that it cannot find a device. This has me perplexed.
    Scholar:
  • 134 Answers
HP Color LaserJet 28xx All-in-One Series - Full Driver Uninstall/Reinstall Instructions Information This walkthrough details comprehensive instructions when a total uninstall/reinstall is required. Details
  1. Go to Start, All Programs, Hewlett Packard, CLJ2840, Uninstall (If a failed install or previous uninstall has been performed, it may not be listed). Once the Uninstall is complete you will need to restart your PC (if applicable).
  2. Go to Start, Control Panel, Add/Remove Programs . Please remove the following entries:
    • Image Zone
    • Extended Capabilities
    • SW update if any are listed
      NOTE: Other types of Firewall and Antivirus programs may need to be removed as well to prevent any blocked ports from interfering with the installation process.
  3. Please insert the CD for the printer into the disk drive and exit out of the automatic web startup.
  4. On the desktop, double-click My Computer and open the drive where the CD is located.
  5. Double-click the Util folder, then double-click the CCC folder.
  6. Locate the scrubber.exe file and . Double-click this file and the mouse will become an hourglass for just a moment. This indicates the scrubber completed. HP recommends running the scrubber.exe file twice to ensure it was run.
  7. Ensure no additional programs are running and then go to Start, Run and type MSCONFIG .
  8. Choose Selective Startup and uncheck the Load Startup Items box.
  9. Go to the Services tab and uncheck the Hide All Microsoft Services box. Uncheck any remaining firewall and antivirus programs.
    NOTE: These items will need to be restored after software printer functionality has been established.
  10. Download the firmware update from the driver download page: http://www.hp.com/support/clj2800 Choose the PCL 6 driver in the printers list when prompted. The printer will go through an Erasing/Programming stage and then will restart itself.
  11. Reinstall the software and restart the computer whem prompted and, allow the PC at least five minutes to finalize the installation.
  12. Download the 2840 software update from the drivers download page: http://www.hp.com/support/clj2800 Choose the CLJ2840 PCL 6 driver when prompted. After installed, there will be a prompt to restart the PC. After Windows comes back up, allow it five minutes to initialize.
  13. Restart one more time and test at this point. At any time, if Windows (or any programs within) prompts about firewall blocks, unblock the files specified.
If everything is running fine at this point, go back to MSCONFIG and run the normal startup then restore the non-Microsoft services that were unchecked in the Services tab and check the remaining boxes again. Reboot one last time and test printing and scanning functionality of the printer.
I hope it helps!!!
Posted on Dec 05, 2008
  • 162 Answers
Try scanning using ONLY the Paint program
    Master:
  • 474 Answers
ALright, i read about how you have tried re-installing and getting updated drivers and no go.
Usually when this happens, it takes a while and then eventually Microsoft will develope an update, but i wouldnt hold your breath.
You can try the Automatic updates and see if Microsoft has an update. Also, try switching the USB port you have it plugged into. I have seen Vista creat a different port for the scanner and on for the printer ( a virtual port) wicth both connect at the same USB.
You can try this.
Go to START>PRINTERS AND FAXES>PROPERTIES
When it opens, go to the PORTS tab.
The printer should be on LPT1
Itry moving it to LPT2, apply and close and restart your P.C. and see if it redetects the printer and works.
I had a Lexmark that was an all in one and it made ports for the FAX the PRINTER and the SCANNER and they where all using the same port but the printer took priority, booting out the scanner and Fax.
I had to designate each to its own port to get it to work.
Give it a try and get back to me if you have any questions.
  • 1,879 Answers
Q: Is your Vista a 32-bit or 64-bit ?
Q: Can you still do a standalone copy (on the printer only)
Try scanning from Microsoft Paint (located under Accessories)
    New Friend:
  • 50 Answers
Have you tried unistalling and reinstalling the software that came with it. There are probably something messed up there. Is the printer as new as the Machine?
    Sergeant:
  • 217 Answers
It also happens if some of your windows files are corrupt or go missing  so the pc doesnot supports some of the features while the remaining features work.as u said you have uninstalled and reinstalled the software again n again i dont think its a problem with the software after trying out so many installations.i would firmly suggest to reinstall the new operating system and then install the hp printer/scanner drivers it will work properly.
  • 1,861 Answers
I had the same issue.
I got mine to work by downloading the "HP universal print driver" 64 bit I think. Try that.
    Genius:
  • 1,239 Answers
Hi you can ask this problem at Main support number800-474-6836
  • ABHISHEK.C
    ABHISHEK.C Dec 05, 2008
    i think this is a software issue install and a new one..then the problem will be solved
  • 19,396 Answers
This is probably only a software problem, reinstall all printer software from disk.
  • 2 more comments
  • Ginko
    Ginko Dec 05, 2008
    If HP Director has 'gone' and the evidently 'new' HP Solution Centre does not run, then this is probably a software issue.
    Unplug printer USB before reinstalling the software, then perfor a full software setup using the printer disk.
    Start software installation with USB cable unplugged, the software setup program will ask you to connect the printer USB.
    That should fix the problem.
  • Ginko
    Ginko Dec 05, 2008
    As I told you, reinstall the software first, that should resolve the issue.
    Click here to see in detail how to remove the corrupted software and reinstall the software.
    Additionally,
    Here is support page for your model.
    If you need to contact HP in the future, use the Diagnose problem or Chat (HP Instant Support), if you send them an email you may get no answer back.
  • Ginko
    Ginko Dec 05, 2008
    That is because you installed the drivers in the wrong way and Windows installed the default driver (that is not good).
    I am telling you that this is probably a software issue.
    Remove the old software and install it again, starting setup with printer not connected.
    Follow instructions here to remove the corrupted software and reinstall the software.
    Alternatively get instructions from (HP Instant Support),
    The problem is not weird or uncommon, it is the most frequent problem on printers, the driver is wrong, any software need to get access through the driver to use the printer, that is the reason why no software is working.
  • Ginko
    Ginko Dec 05, 2008
    Additionally, to install a driver on Vista you may need to bypass what is called UCI (User Control Interface) to do this, instead of running the driver installer file by double clicking on it, you click right button of mouse on top of the file, and chose "Run as Administrator" from dropdown menu.
    see: Run As Administrator
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
We have downloaded the HP 2840 software and drivers and installed it. But the scanner is not working. The Icon in the desktop is not displaying only HP image and Software updates. Help us
Are you using Windows Vista, try using a computer with windows XP. for some reason the HP vista driver is not always compatiable with windows vista.
Dec 11, 2009 | HP LaserJet 2840 Printer
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
Aug 14, 2009 | HP LaserJet 2840 Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
Scanning not happening in Hp lasejet 2840 in windows vista
check to see if that printer requires direct plug into wall socket. and did that printer driver come on cd or did you get it from www.hp.com?
Dec 12, 2008 | HP LaserJet 2840 Printer
HP 2840 scan to folder problem
Kiss off your money and get a commercial grade AIO
like Ricoh or Samsung. The 2840 has been a problem for us since the check cleared. 2840 Phone support is worthless. All the other HP products we have work perfectly every time.
Jun 11, 2008 | HP LaserJet 2840 All-In-One Printer
18 people viewed this question
jasbo
jasbo
