Question about Hitachi Televison & Video
I have a Hitachi 32LD8600 LCD tv and the sound has started to have a kind of razzling noise and when it does that the normal sound disappears. It is ok for a while after I turn the tv off and back on again.
JMuskovitz
  • 135 Answers
SOURCE: Humming noice
I have seen similar problems (features?) with Syntax LCD TVs. One thing to try is to make sure that the backlight brightness is set to its highest setting. On my Syntax, when this is set to a darker setting, it produces annoying hum through the speakers. Mine also is smart about turning *off* the audio amplifier when set to zero (or mute), which sounds like the behavior you are describing.
Posted on Apr 17, 2007
SOURCE: hitachi 50 inch projection tv model # 50ux58b
how to clean the lenses?
Posted on Feb 17, 2008
milmar
  • 50 Answers
SOURCE: Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
Posted on Aug 01, 2008
Ecollier2012
  • 3459 Answers
SOURCE: beeping noise when I turn on my TV
www.TvRepairKits.com just added a kit for the "chirping set" problem.
Hope this helps,
Posted on Dec 22, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
My hitachi 32ld8600 keep turning off after 4 minutes
This is a good indication that the capacitors on the power supply are failing. Is it under warranty? If so, contact Hitachi to find a certified service center. If it isn't, you will have to find somewhere to take it to get the power supply replaced or fixed.
Apr 18, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
MY TV all the sudden lost sound and is just making static noise
Hello:
This model has problems with the power supply causing audio issues, There are bad capaictors on the power supply that causes this problem, have the power supply replaced to restore unit to normal operatin spec's
Jan 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
TV doesn't turn on, three lights (blue, red, red) goes thru the normal start up, but stops with red lamp light on.
my samsung lcd 40 inches.power on blink contineoisly when we switch on LCD KIND GIVE SUGESTIONS
THANK U
BAKSHI
vkb3@rediffmail.com
Nov 14, 2009 | Hitachi 50VG825 50 in. LCD HDTV
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Samsung LW32A23W LCD TV
check out for sound module, the noise filtering system of the module is bad .replace it
Oct 11, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Televison & Video Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
