Question about Insignia IS-LCDTV32 32 in. Television
Power i have the 32in lcd model # ns32lcd and my prob is that the power comes on but i have green,red,blue, stripes right down the middle no picture what do i do???
  • roganp Dec 13, 2008
    My did the same thing there has to be something that can be done
  • 58 Answers
Your lcd panel has been damaged. its non repairable.
Posted on Dec 05, 2008
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Dont know if you can help but....I just bought an older model pick up(1989 toyota)it had no radio in the dash, I have a Kenwood CD player i want to install but I dont know the color codes of the wires in...
Nice radio installer link HERE
Check out the lower wiring guide.
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C +12 Volt Ignition Wire Gray Red
D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
E Right Front Speaker (-) Blue Gray w/ Black Stripe
F Left Front Speaker (-) Purple White w/ Black Stripe
G Ground Wire Black Black
H Power Antenna Wire 1 Blue (join wires 1 & 2
I Power Antenna Wire 2 together to this blue wire)
J Do Not Use
K Right Rear Speaker (+) Red Purple
L Left Rear Speaker (+) Black Green
M Right Rear Speaker (-) White Purple w/ Black Stripe
N Do Not Use
O Do Not Use
P Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 14, 2009 | Car Audio & Video
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
What do the wiring colours mean?
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe Left Rear Spkr (-) = Green w/ Black Stripe Right Front Spkr (+) = Purple Gray Left Front Spkr (+) = Dark Green White Right Rear Spkr (+) = Blue w/ Orange Stripe Purple Left Rear Spkr (+) = Brown w/ Blue Stripe Green Power Antenna/Amp = Blue +12 Volt Battery Wire = Yellow +12 Volt Ignition Wire = Red Right Front Spkr (-) = Gray w/ Black Stripe Left Front Spkr (-) = White w/ Black Stripe
Jul 07, 2009 | Car Audio & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Green red blue stripes down the middle 32in lcd I have a similar problem. When I first turn the tv on, the screen is mostly black, with small vertical colored lines shown scattered across it. Then,...
Hi
Base in your complaint, you have defective Ribbon Wire thats connected to the LCD to Mother board..
Or you have loosed contact to Pin Ribbon Wire that needs to re solder..
Thanks!
Jan 28, 2009 | Televison & Video
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Insignia IS-LCDTV32 32 in. Television Logo
180 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
