Question about Mr. Heater MH175KT Open Flame Utility
It runs but it puffs smoke every 3 - 5 seconds.
Please
  • 232 Answers
I am not real familiar with the Mr Heater units, although I have been around Reddy Heaters for well over 30 years. The principal is the same, after all, Mr heater is a foreign knock-off of the Reddy Heater.
Check, in this order:
1. shine a flashlight in the tank- look for water droplets rolling around on the bottom.
2. check the fuel filter for restriction. A blocked filter will cause starvation.
3. with soapy water check for air leaks from the air pump to the nozzle. An air leak will cause reduced fuel delivery.
4. check the pump pressure, bring up to factory specs.
5. If you have turned the adjustment screw, move #5 up to #1.
6. check or replace the nozzle.
7. If the fuel delivery system checks out OK then you have an electronics problem, and I’ve been told that Mr Heater parts are rare and hard to come by.
Posted on Dec 06, 2008
Hi my 2006 3.2 blows puffs of un-burnt diesel smoke intermittently after it has been driven in traffic
have the variable vanes in the turbo checked for correct operation
there is an actuator that is vacuum
electrical sensor controlled and the vanes may be sticking at slow engine operations as on traffic
the smoke color indicates incorrect air/fuel ratio and the turbo is a point to investigate
Sep 10, 2016 | 2006 Mitsubishi Pajero 2.5
A small puff of smoke came from top right of laptop
Was it dust? Could be the power in socket/plug.
Feb 09, 2014 | Advent 6552 Laptop
Small puff of smoke coming through the top right of the laptop
The fan usually wont fail in that manner, If it still works normally, you can go to www.almico.com and download a program called speed fan. It is free and it will tell you the temp of everything in that computer.
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Mountfield push along LS45 mower. Why does it pulse as it runs and make puffs of black smoke?
sound like you need to clean the carb the primer bulb is only used to start not run
May 20, 2012 | Garden
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
Ignites about every one half second puff blue smoke when fire puff blue smoke will not run continous
statelinespe,
You have a classic reddy heat problem. Daytons are made by Desa the same as reddy heat so they are the same. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix it.
Thanks fo using FixYa and for the great rating.
hardrocko
Dec 29, 2010 | Dayton (3VE50) Oil Filled Liquid Fuel...
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mr. Heater MH175KT Open Flame Utility Logo
438 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
