Question about HP Pavilion dv6000z Notebook
Keyboard my ploblem is that the part of keyboard doesn't work well
    Scholar:
  • 68 Answers
It could be a loose connection, or it could be a bad keyboard. Either way, you are going to have to remove your keyboard. This is not too difficult, but be gentle with it.
Start by shutting down the computer and taking out the battery. Look around the screws in the battery compartment and you will probably see 2 of them that have a little picture of a keyboard. Remove those screws. Now, open the laptop lid all the way. You should be able to pop the bezel above the keyboard out, starting at the right side. Gently pry it up, working your way to the left. Once that is removed, there should be about 4 screws holding the top of the keyboard in, remove those. Now gently lift the top of the keyboard up and you will see the flat ribbon cable that connects it to the computer. This slides into a little connector on the motherboard, and will have a little tab on each side that locks it into the board. Slide that out and the ribbon should come out. Check it for problems, and make sure it is clean. You can use a standard pencil eraser and gently "erase" on the connectors. Now, reinsert it (or the new keyboard, you can get them relatively cheap on eBay) back into the connector all the way, and push the locking tabs back down. Put it all back together and see if your problem is solved. If not, you will definitely need a new keyboard.
Good Luck!
Posted on Dec 05, 2008
My laptop getting balck screen suddenly if we are not able to work for 15 min? what should i do to solve this problem....?
Hallo ravikumarp12. i think it`s a cooling ploblem. your lappi runs hot and turs off, for protecting you from absolutly distroying the CPU.
Try to clean the heatsink or meyby your CPU-Fan doesn`t work.
Hope it works
mfg Gue.
Feb 28, 2013 | Lenovo Computers & Internet
Keyboard doesn't work
To determine if the motherboard is faulty, connect an USB keyboard to your laptop an see if the keyboard works properly. If so then the laptop keyboard may only need the keyboard connector unplugged and then plugged back onto the motherboard.
Nov 29, 2012 | Gateway NE56R10u Laptop
The letters on my keyboard doesn't work
Dust the keyboard to remove any debris.
If that doesn't work, re-seat the keyboard. This requires disassembling much of the laptop. www.ifixit.com has great guides on how to complete this for every model of mac laptop.
Nov 05, 2012 | Computers & Internet
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
Try connecting an USB keyboard to your Acer laptop. If the external USB keyboard does not work the the laptop is faulty.
If the USB keyboard works then reseat the laptop's keyboard connector to the motherboard, it may have become loose.
Mar 02, 2012 | Acer Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
My f10 lite is on and keyboard won't work
Unplug it and replug it, if it still doesn't work restart your computer. If it still doesn't work, it could be the keyboard, or it could be the port it's connected to.
Aug 23, 2011 | Computers & Internet
My keyboard in my laptop is not working.. please help ! it doesn't work at all even the synapse pointing device
Reference the manual on how to remove the keyboard from your computer and than reconnect the cable. If this doesn't work, than the keyboard needs to be replaced.
Jul 03, 2011 | Acer Computers & Internet
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
