Question about Zyxel Prestige 334 Router
I m not able to understand what is exectly router is and what is swtch
  • 19,396 Answers
HUB, a simple mutiple connector, that connects more network devices.
Switch a network connector that connects multiple devices performing a simple data flow control.
Router: This is a computer (yes there is a computer inside your router) that assign to each device an unique identificative on local network, called the IP address.
Devices communication on the network is routed to the best path using determined alghorithm.
Posted on Dec 05, 2008
ITEM 98568 P2138 $07E8 1/2 GENERIC THROTTLE/PEDAL POSITION SENSOR SWTCH D/E VOLTAGE CORELATION
You need to understand the causes of this fault, it is not always the throttle pedal sensor, it can also be wiring or the throttle valve sensor. Read about it at the link. P2138 Throttle Pedal Pos Sensor Voltage Correlation DTC
Jun 20, 2017 | Cars & Trucks
Wireless router password is not being accepted by my kindle 0682 first gen.
The encryption on the router might be too recent for your old Kindle to understand. When the Kindle came out, it probably could understand WEP protocol, then came WPA and WPA2 etc. Modern routers would likely be using WPA2 and the Kindle doesn't understand that.
If you can, turn off any security settings on the router and then try to connect the kindle again. If it connects then it was definitely the security settings!
Feb 19, 2017 | FIRST Computers & Internet
Aspire 5720 wireless swtch
It looks like your Aspire is A,B,G wireless only where as your D-Link is N. The N is backward compatible, with your computer. You many need to enable one of these on your D-Link to get the Acer online. Look for an option on your router to enable "legacy mode".
Dec 02, 2013 | D-Link Computers & Internet
Nokia phone 3100
following this instruction,
1.remove the white rubber ontop the power botton.
2.find a metal that can touch both edges of the tip where the power botton was removed from (positive -positive).
3.your phone will come on then you can enjoy your phone without switch botton.
Jan 11, 2010 | Nokia 3100
How to switch wireless on & off, my laptop won't pick up my wireless router at all it only works wired
CHECK THE MANUAL OF THE LAPTOP THEIR WILL BE SPECIAL SWTCH ON THE SIDE OF THE LAPTOP OR HOT KEYS MIGHT BE THEIR TO INTSANT ACESS TO WIRELESS A WIRELESS SIGN WILL BE VISIBLE
Oct 18, 2009 | Evesham Voyager 5800 Notebook
Connecting the power swtch cables and others
I understand from this post that you need to connect the mobo to your casing/chassis.
There is a detailed diagram that can be found on the owner's manual that ships with your board. In case you do not have this, you can find one from this site:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope this helps.
Jun 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wireless connection doesn't stay
change the router belkin have major problems like this, go for a sagen or other makes you will find cheaper models work much better and get a better range also
Apr 16, 2009 | Acer Aspire One PC Notebook
Connection of DLINK router(DI-524) and 8port10/100M ethernet mini swtch
If the switch doesn't have an "uplink port" or autodetect the port speed, then you will need a crossover cable to connect the DLINK to the Surecom switch. If this is the same issue then rate this one so it can be closed. If not then let me know how it goes. Good Luck
Sep 28, 2007 | Computers & Internet
Zyxel Prestige 334 Router Logo
55 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
