KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Posted on Dec 05, 2008
Kitchen Aid KSRP25F Ice Maker
I am getting no ice from my Kitchen Aid. The LED red light is blinking when I open the freezer. What can you tell me?
  • 1 more comment
  • ctipton66 Dec 29, 2008
    The ice maker in my Kitchenaid side by side refrigerator (KSRW25F) is not ejecting the ice, once it freezes. It also is not filling up. I have cleaned out the ice tray with warm water and it will go around, but it will not fill up. If I add water to the tray, it freezes, but it will not empty.
  • times1 Jan 11, 2009
    Ice Maker is not making any ice. Does not seem to be filling tray?
  • bgrassdad Jan 24, 2009
    Ice maker stopped making ice, no water in tray at all.  I heard water "running" one day inside the frig, but there is not water on floor, etc, all looks normal.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3611
Points
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Ice Maker not working in Kitchen Aid Superba. Light is blinking constantly on right side wall of freezer. Is this normal?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
44
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
5helpful
2answers
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
35helpful
6answers
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
35helpful
3answers
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
