Question about JVC XV-N5SL DVD Player
Will not switch on
Hi all, problem with my dvd is it won;t switch on love the player since we;ve had sky plus it hardy used alway switched off but on stand by "left pluged in at mains". Will not power up switchs on for 1/2 second,is it worth repairing.
  • 10 Answers
SOURCE: DVD Player keeps switching on and off
Plug in the DVD player into a different power outlet to see if it's faulty power outlet. If the DVD player is still acting up, then it's either a faulty power supply unit or a faulty main board. Either way you'll have to get it fixed.
Posted on Jul 29, 2007
0 characters
1 Points
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Copying from Sky Plus to DVD with Panasonic DMR-EX773
Go to planner...highlight the program that you want to copy.
Press right on the navigation keys then the green button then select.
When you are ready press select to start followed by record on your recorder...
Feb 21, 2012 | Panasonic DVD & Blu-Ray Players
Hi there. I have a sky hd plus box and I am unsure how to connect it to my Samsung BD-D8900 Blu-ray HDD player so i can record programs from the Sky box. Hod do I do this please?
Connect the Sky boxes AV out to the line in of the Samsung using a Yellow/Red/White RCA cable. Then in the source button of the Samsung choose External In or Line In and just hit the record button. The only problem with this connection is that you will have to leave the Samsung selector on Line In even just to watch programs from Sky. This is called a looped through connection. Your Sky is looped through your Samsung Recorder.
Sep 11, 2011 | Samsung BDD6500 Bluray 3D Player
Have samsung dvd sh893m all though followed instructions from both dvd & sky manual cannot get signal from digi box ?
if you have followed the sky instructions and connected the aerial to the sky box first, don't. Always connect the aerial to the digital tuner first as the sky box and any other equipment will reduce the signal strength.
Mar 29, 2010 | DVD & Blu-Ray Players
Help how to best connect sky hd and PS3 to a Jamo
you will have to use a component cable or optical lead from your ps3 to the jamo and sky hd to be connected via scart.
for best image,buy an HDMI CONNECTORS switch that will allow you to run many HDMI TO IT and from the switch you only need one to the tv so the jamo still output to the tv.
remember that you will have to get an automatic one so that it can select when you are using each element.
Mar 04, 2009 | Jamo DMR 60 DVD Player/Receiver
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
JVC XV-N5SL DVD Player Logo
22 people viewed this question
Top JVC DVD & Blu-Ray Players Experts
Are you a JVC DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
