Question about E-Machines eMachines Desktop PC
Unbootable EMachine My T1440 EMachine will no longer boot. I'm sure it's hardware related since the PC is over 6 years old and I always ran a firewall/av software and never opened unknown attachments. I tried to load the restore disk that came with the PC but to no avail. Any thoughts what hardware may have gone bad or how to check it out? Thanks, Dan
  • 22 Answers
Unless you have data on your HD you really want, i would chalk this up to a loss. If you cant boot up, and you cant get into setting while booting up then you probably need to take it somewhere. Being as its so old, i would consider a new PC. There cheap enough now that a few hundred dollars gets you a nice new one, and i would steer clear of E-machines if you can, there very problematic machines.
Posted on Dec 05, 2008
Compaq Presario 900 Series PP2140. No hard drive. Trying to boot from USB - but USB is not listed on the boot order menu. Any Ideas?
Cannot be done since the cmos does not have a boot option from a usb device. Need a bootable cd in lieu.
Sep 18, 2017 | Compaq Computers & Internet
Can't get the cover off
Ensure that all required screws have been removed. Make sure that you're removing the correct panel. Clear any cabling that make be hanging up your removal of the panel.
Nov 12, 2012 | eMachines T1440 PC Desktop
I hear two beeps when i conect power suply on my emachine t5212 model
Very sorry about your son.
If you can't find the real problem, you can always put that hard drive into another PC to get the files. If so, be sure to looking to a potential "jumper" setting on that drive for it to be recognized.
May 05, 2012 | E-Machines T5212 PC Desktop
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
I have an emachines T1440 desktop. the front face of the machine is broken, the power cord, and the wires from the power cord to the power supply box. What type of case or tower can i use the remaining...
Luckily, eMachine uses a generic system board. You can purchase a case from any computer store. The only thing to watch for is the plate in the rear of the motherboard, make sure it matches your ports. Again I believe you can use the one from your eMachine.
Nov 12, 2010 | eMachines T1440 PC Desktop
Where do i find windows 98 disk for the emachine
try going to there web site look under drivers . that is a rather old os not sure there will be an support, you can always find old disc's at local thrift store....
Feb 01, 2010 | E-Machines etower 500is PC Desktop
I have an emachine that is 5 years old. Always
YOUR PSU (POWER SUPPLY UNIT) MAYBE THE CULPRIT. If the power to your cable which fits the computer is ok, then the supply unit is usually at fault. You can buy these pretty cheaply on ebay and they are very easy to fit, or if you are not into that find a mate who can! beleive me... its pretty easy.
Jan 04, 2010 | E-Machines eMachines Desktop PC
EMachine T1440 will no boot on
There is a battery inside the pc, remove it and replace it with a new one. Leaving it unplugged for that long taxes the battery too much. This should help and also plug everything in and reset the power switch on the back.
Aug 19, 2008 | E-Machines eMachines Desktop PC
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
