Question about Creda C361E Electric Kitchen Range
Back ring cant be adjusted up or down when turned on
The switch turns on the ring but wont adjust it up or down .
if the problem is the switch how do i get it off and where
do i get a replacement .
    Scholar:
  • 160 Answers
Look for a manual at some of these. you can order parts from most, or from the manufacturer.
http://search.msn.com/results.asp?cp=65001&RS=CHECKED&Form=CO&v=1&cp=65001&q=appliance+manuals&Submit1=Go
Posted on Dec 05, 2008
I am having a problem removing the distributor on my 1988 mercury tracer. I have removed the adjustment bolt but it won't break free. any ideas?
No, don't beat it up. Does it turn with the adjustment bolt out? Make sure no other retainer bolts holding it. If you can turn it back and forth as it should with adjuster bolt loose or off, just keep pulling while twisting- the O-ring seal on the distributor may be sticky with age.
Sep 14, 2015 | 1988 Mercury Tracer
How to fix 20200 ringer
Most phones have a switch of some sort to adjust the volume - have you accidently turned it right down? Check the sides and bottom for a small slide or dial type switch and adjust it. There may be a symbol that is probably hard to see.
Jun 18, 2014 | Northwest Bell NWB20200 Nw Bell 20200 Wht...
Change ignition switch
double posted.
adjust what, type out what you did and expected and what didnt work.
1: I cant turn key ,its locked.
2: i turn key to Ignition1 pos. and get no CEL ,brake and charge light, Fuse blown
3: turn key to CRANK, and the engine starter is dead, no crank
4: the steering wheel is locked, or wont lock.
5: i cant extract the key or put it in.
pick one or add one.?
Nov 30, 2013 | Geo Tracker Cars & Trucks
Bought a new Fluidmaster from Home Depot and lost my instruction sheet in english......Colony FitRight two piece toilet. after flushing, the water still runs (most times) into the refill tube. It looks...
First, turn water off at wall valve under toilet. Next, find the plastic ring/collar almost at the bottom of the fluidmaster's shaft inside the tank. Pull UP on the locking ring/collar until it comes loose. This releases the upper shaft from the lower shaft and it can be pulled up or pushed down on the lower shaft to make the entire shaft taller or shorter. It has to be pulled or pushed over some plastic grooves, so it may take a bit of twisting and/or moderate force to move it. You must LOCK the ring/collar back down to the bottom of the upper shaft before turning the water back on. Locking the ring back down may require a bit of twisting back and forth to line up those grooves inside the shaft. Only turn water back on after this lockring is pushed securely back down, after adjusting the shaft height.
Nov 10, 2010 | Home
My weber genesis wont stay lit. i can light the
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 31, 2010 | Weber Genesis Silver C Grill
How to change the clutch cable on a 2003 Buell Firebolt.
drain primary fluid,remove clutch inspection cover make sure not to lose spring hex when removing,with small screw driver turn adjuster so the hex nut screws out (left handed threads) remove ball and ramp off cable careful not to drop anything into primary.okay now go up cable to mid-range adjuster and back off (together) then go up to clutch lever and remove there a snap ring that you should replace and be mindful of cable rounting then go back down to primary cover and remove,when putting new one in be sure not to over tighten and don't forget o-ring, after all reinstalled to adjust clutch screw adjuster in to it lightly seats and back off 1/4 to 1/2 turn and adjust mid range until you have a 1/16 to 1/8 freeplay at lever pull and release three times to make sure the ramp and ball have seated good luck
Jan 12, 2010 | 2003 Buell Firebolt XB9R
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Creda C361E Electric Kitchen Range Logo
137 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
