I need a schematic diagram for a SONY KV2585SA
Could anyone help me with a schematic (circuit) diagram for a SONY KV2585SA. Would greatly appreciate it.
3 Suggested Answers
  • 10594 Answers
SOURCE: Sony KV-BZ212N50 schematic diagram
Service Manual of KV-BZ212N50 is available on charge basis.
Posted on Jul 29, 2008
SOURCE: Mitsubishi model No. WS-55807 - In need of schematic please
I have a WS-55807 that will not power up. When the power button is pressed I hear a click from the back of the set, the timer light comes on and 3 seconds later I hear a click from the back of the set, and the timer light goes off. I started checking power to the unit with a voltmeter. For those intersted I have attached scematics: I verified that the PCB main fuse is good and there is 120V at point PT. 9f453c1.jpg
From what I can tell is happening, the power button is pressed and the P-ON transistor is given a signal to conduct which causes K9A50 to close. K9A50 opens after about 3 seconds.
I am looking for other troubleshootinng steps. I have checked fuses F9A01 and F9A06, both are good. What are some other things to check for? Where does the P-ON signal come from?
In the switched supplies regulator circuitry I found fuses F9A04 and F9A05 blown (denoted by red lines thru components). I jumpered around F9A04 and F9A05 with good 5A fuses and the TV powered on. However when the set was plugged into an outlet there was a huge power draw (sparks from the outlet).
After jumpering around the blown fuses, the TV stayed powered on for about 30 sec and then powered down. I pressed the power button a few more times and the same result. The TV stayed on for only 30 sec.
I pulled the middle PCB whichs holds these circuits and I found the
D9A60 diode open and IC8C02, one of the convergence IC's fried. I don't know if these were like this before or after jumpering.
I replaced all bad components and I am back to square one. The K9A50 relay stays closed for 3 sec and the set does not power on any further.
Comment by TV_ITGuy, posted on Dec 19, 2007 Thanks for the advice ctf1800. I have read several posts that speak of the DM unit. I have looked in the back of my set and the DM unit is not in the location shown in the pictures. dcb8806.jpg
As I hope you can see in this picture, there is no DM unit to the far left, just open space. Also the service manual for the V17 chasiss does not speak of a DM module.
I checked the reisitors on the output of IC8C02 which are a couple of 3.9 ohm resistors in parallel. When I test them I get approximately 1.9 ohms, which is what it should be with them being in parallel.
Please let me know if I am off base on any of this. Thanks Comment by TV_ITGuy, posted on Dec 19, 2007 Also, I have replaced both of the Convergence IC's when I replaced the fuses and diode. postsolution.gif Post Solution
addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Dec 19, 2007 2%20stars.png
Rank:wizard_s.gif Wiz
Rating: 84%, 2716 votes
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
Comment by ctf1800, posted on Dec 20, 2007 there are six fusible return resistors ranging from 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms. I would lift one side of the resister out.
check for any caps that look puffy and check the horz. out put transistor.
Rating Locked! (?) TV_ITGuy has rated this solution as Thanks for Trying
Hope this helps
Posted on May 29, 2008
Schematics/Diagram for Bosch SHE68M05UC/50
The last two Bosch Dishwashers I have owned, the detailed schematics were rolled up tight and placed in behind the left front foot rest.
Jan 18, 2013 | Bosch Evolution 800 SHE68M05UC Stainless...
Harley fairing wiring diagram
Hi Jim, for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Oct 12, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
I would like to ask if anyone got a schematic diagram og Sony Trinitron kv-21gmr1 model?
best i can give you is a circuit diagram located as an attachment here
if you found this useful please vote for me
Mar 30, 2011 | Televison & Video
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
Hey every one im looking for kdl-w40a12u sony bravia schematic diagrams, can anyone help me with that please.thanks a ton in advance
The world is full of free, useful information but schematics for tv sets are not part of the equation. If you want them, you usually have to pay for them. Maybe if you post the specific problem you're having, I can help point you in the right direction as far as fixing it. Schematics don't fix tv's, people do.
May 21, 2009 | Sony KDL-W40A12U 40 in. LCD Television
TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
May 17, 2008 | Televison & Video
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
4,423 people viewed this question
Top Televison & Video Experts
