Question about Dryers
When the dryer is turned on, you can hear a clicking sound but the dryer does not come on.
Bought a new one...it appears the motor was fried.
Posted on Dec 09, 2008
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
Dryer is not turning on
That sounds like a bad door switch to me. My Frigidaire dryer service manual and more is HERE
Nov 27, 2012 | Frigidaire Dryer Thermal Fuse Thermal...
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
When I turn on dryer I hear a clicking sound and the dryer turns off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore 72062 Gas Dryer
When i turn on switch all i hear is a clicking sound but unit will not start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 24, 2010 | Frigidaire GLER341A Electric Dryer
Dryer isn't drying anymore
check the ignitor first it should make a clicking noise within 15 seconds upon turning on the dryer. If no clicking sound is hear you have a bad ignitor for your burner to ignite it
Feb 13, 2010 | Dryers
No heat
If you have a gas dryer check the ignition ignitor. When you turn on the dryer you should hear a clicking sound within 15 seconds. That sound is the ignitor clicking to throw a spark to the burner to ignite. If that sound is not hearf the ignitor is at fault
Wont turn on, makes click sound when you push the start button. The click sound is near the motor.
The clicking sound your hearing is in the gas valve and or ignitor that are located near your dryers motor. It sounds as if you have a problem with the motor or motor switch itself. This can be repaired but the repair most often requires the replacement of the motor itself.
Jan 09, 2010 | Kenmore 73952 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Heat kick on then off
these are heat cycles,
the click you are hearing is the thermostat turning the element on or off, most dryers try to acheive a temp of 160 - 180 degrees, when reached the element shuts off for a bit to cool down and not scorch your clothes
you do not have to worry about this
May 26, 2009 | Kenmore Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
