Question about Sony MHC-RG660 CD Shelf System
"mecha error"? I was reconnecting the front speakers while I had music playing through the system (probably not a good idea I know). When I picked up the amp to move it back to its original position, I heard a small pop and it shut down. If I try to turn it on now the display shows "mecha error", followed by "eject" then "standby", at which point it goes into standby. I'm hoping that this could just be due to something like a blown fuse, but I really have no idea. I'll probably have to take it to be fixed anyway, but can anyone shed some light on this?
  • gary g54 May 28, 2008
    same problem same cause not reset itself yet though any solutions???
I've dismantled my system found the top fuse had blown on the transformer also aligned the cd tray all works sweet now wahoo :)
Posted on May 29, 2008
Roughly 15 mins after posting my problem the stereo returned to normal and has been fine since then. Thanks for the input anyway.
Posted on Feb 19, 2007
    Problem Solver:
  • 30 Answers
Yes a problem on tray mechanism,and needs timing or alignment,caused by movement while playing any tapes or cd's,need's qualified serviceman.
Posted on Feb 18, 2007
Mecha error 12
Could this answer from FIXYA be the same issue?
rmaxxx69
  • 3 Answers
SOURCE: Mecha Error 12 on Kodak Photo 6800 printer
I had a 6850 with the Mecha error 12. No listing in the service guide for this error. I took the front of the printer off and observed that the cut head was not moving far enough to the left to trigger the sensor. I realized that a screw of unkown origin had fallen down behind the cut head and was preventing it from triggering the left sensor. It took a curved pick tool and a pair of tweezers to get it out. I don't recommend taking the cut assembly apart as the alignment is pretty crucial.
Hope this helps some poor sole from the hours of fustration that it gave me.
Randy
Posted on Nov 19, 2010
Mar 13, 2018 | Office Equipment & Supplies
E-Mecha...what does it mean?
Hello cclub2002,
First try to turn it off and then on.
If that doasent work, turn it off for 10 mins and then turn it back on.
If the error continues, let me know.
By the way, to try to get your CD out, search for a hole (2 mms in diameter) It should be near the CD tray, but could be anywhere.
Once you locate the small hole, find a paper clip or smomething as pointy as it, and insert the paper clip in.
Press it had and the CD tray will come out.
Good luck and anything else you need let us know,
Dahaka
Jul 26, 2008 | Nakamichi SoundSpace 5 Shelf System
In my sony home theatre MHC - GZR88D i want to play music as dvd , usb ,etc.... ,don't played only one word is shown that mecha error , what can i do
Probably means there is something wrong with the DVD drive. Check that a disc is not inserted wrong. You could also try cleaning the DVD lens.
Jun 28, 2015 | Sony Audio Players & Recorders
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Randy
Apr 15, 2009 | Kodak 6800 Thermal Photo Printer
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
The soud has no high frequences, how can i regulate them?
There are no settings for this. I have the same problem, I think the speakers are tired. Ours gets used as a music system at parties so has suffered quite a bit of abuse. I have improved things a bit by swapping the front and rear speakers. The rear ones don't usually play as loud as the front, so were in better condition. Unplug the mains first, disconnect the wires at the speakers, move the speakers round, reconnect making sure that you keep + and - correct and give it a try.
Feb 10, 2008 | Sony DAV-SC5 System
Mecha error
I had the same problem. My unit would not eject CDs. I was able to fix it by hitting the reset button. That restarted the whole unit and reset all the settings as well, but now I'm not having any issues with ejecting CDs.
Oct 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Sony MHC-RG660 CD Shelf System Logo
986 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
