Question about Microtek Computers & Internet
I have a microtek 17' monitor model is 41f
Which display is shaking from the top to bottom plz give me a some of tips .
  • 104 Answers
This can be caused by low Screen Refresh rate. Eg 60Mhz. To increase this go to Display propertes > Setting > Advance > Monitor > Screen Refresh rate
Your graphic driver must be installed correctly to be able to make this change.
Please tell me If this dont fix
Best regard
Posted on Dec 05, 2008
My monitor 17" Samsung 794MG CRT. Already Display setting 1024 x768 (Problem is Screen are Vertically Shake) Request you to give ideal settings for display of above monitor
This depends on your video card's capabilities. Try setting it to the lowest value, and then work your way up. If the screen is shaky, this may be a monitor problem. You may also try to set the refresh rate for the monitor lower, as this can be the cause of shakiness.
Sep 30, 2010 | Samsung 793DF 17" CRT Monitor
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 05, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
Sir i have 17' crt monitor and it gives display as shaking condition .. Could u give me some solution abt that ..
make sure u dont put speakers near ur monitor and any other electrical equipment that can generate magnetic field. (eg. UPS, stabilisers...).
May 19, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
MONITOR Problem
The contrast sign of the monitor appears on the screen. How can I remove it ?
Jan 25, 2010 | Dell E773C 17" CRT Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor problem
1240/1024 and 75hz refresh rate
May 09, 2008 | Samsung 793S 17" CRT Monitor
Monitor having resolution & display problem
Plz change resolution or refresh rate in desktop properties.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
Michael Deni
Level 1 Expert
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
