Question about RCA DCW615R Wireless/Cable Modem
RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed.
RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed. Comcast Flashed my Modem so now I can't set my own WEP keys ,but can only use Passphrase to randomly generate them. So I need the firmware to reflash the modem to factory reset. Holding Rest during power on doesn't do it! From the Comcast Gateway Status Screen: Vendor Name: Thomson Hardware Version: 1.4 Serial Number: 85022321682112 Firmware Version: ST49.04.0Bc Operating Mode: Residential Gateway
  • 2 more comments
  • Wes Miller Aug 24, 2007
    I ended up replacing it with a Motorola SB4100 Cable Modem which has is flashable by it's USB port and I got the firmware for it to reflash if they do anything to it. Maried it to the Cisco Dlink WRT54G Switch Router which has Open Source Linux Firmware....
    Anyone wanta buy a RCA Comcast based Firmware Router? $20.00 Includes shipping anywhere in USA!
  • Dazzler69 Nov 05, 2007
    How do you get the wireless to work again? This sounds like it happened to me. Only works as a modem now. RCA won't help. Nor comcost.
  • Wes Miller Jan 08, 2008
    As per above: They supplied me with the user name and password.
    What was the Name and Password they supplied you with?
    I tried the 8 Sec Reset button and it still came up to the comcast page, I can not get to the security page. All I can do is set up my wireless by Passphrase and look at the modem settings, but can change nothing!
    I since went to a Motorla modem and seperate router, but to sell the RCA on Ebay I would need it back to a factory firmware instead of Comcast's own...The Rat Bastards!
    Thanks Wes
  • Wes Miller Oct 03, 2008
    Didn't work I since trashed it and went with DSL and a seperate Hawkings HRWGM1a Wireless Router.
I had the same issue with my RCA DCW615R. First time my ISP Comcast flashed it back to the old version. This time I could not find anyone who new how to do that. I used to have the software and I have searched the net. Seems they provider RCA does not have it.
This time I called Comcast because I noticed that the 192.168.0.1 brought me to their software update. They supplied me with the user name and password. I was able to get into the firmware and change all the settings using the new firmware. I think the only reason they gave it to me is because my printer is a network printer and it would not work unless I could access the firmware.
The old 192.168.100.1 does not work anymore because that was Cable Modem mode or CM mode. The new address 192.168.0.1 does work but you will need the user name and password from your ISP, this is RG mode or residential gateway mode.
Liked the old firmware better but they both do the same thing. Seems the Gateway works better with the new update. Still I would like to find the old firmware not sure why RCA doesn’t have it.
Posted on Jan 07, 2008
  • jjmack Oct 03, 2008
    Username Comcast
    Password 1234
    Comcast Firmware is on the RCA DCW615R because RCA no longer supports it. Log in using 192.168.0.1 username is comcast password is 1234.
If you deal with your ISP ( my ISP is Comcast) they have flash your firmware to a newer version from them. You will need to access 192.168.0.1 login in using the login in name and password they give you, if they give it to you. Then you can change all the settings just like you use to but using the new firmware update. In order for you to go to the old 192.168.100.1 you would have to have them flash it back to the old firmware and you won't find to many people at your ISP who know how to do this. My DCW615R is working better with the new firmware. I happen to find someone who would give me the password because my printer goes through the gateway using the network.
You will also find that hitting the reset button will not fix your issue. I tried searching the network for the old firmware, I had it at one time, but it is no where to be found.
  • 25 Answers
Well okay, if you truely want to reset the modem back to the dafult factory settings, follow these steps:
Path #1
1.) Unplug the modem from the power cord (on the modem, and not on the outlet).
2.) Hold/Pin down the reset button for 8 secs (should be in the back with a little hold, too small for a human finger, so find something sharp in order to poke it).
3.) Plug your power cord back into the modem.
4.) And it should work, but since you said that method still does not work, then follow Path #2.
Path #2
1.) If you are able to log onto your router's ip address and information screen, (192.168.0.1) then you should be able to reset the modem without pressing the reset button on the back.
2.) Once logged on to your router's homepage, go to the top left of the screen, you will see a tab that says, "Status", go to it.
3.) Once there, look at the left side about mid-page and click on "Security".
4.) And where you see, "Restore Factory Defaults?" with a yes or a no button?, click yes and finally click "Apply" button.
5.) Your done!
Posted on Dec 27, 2007
How do I password protect my network using my mac with the rca DCW615R
You can protect you passsword using LoginTrap http://www.protemac.com/LoginTrap/.It’s really good program. Try)
Jun 26, 2010 | RCA DCW615R Wireless/Cable Modem
Trying to set password for RCA DCW615R router. Want to keep others from using it for their internet. How?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 27, 2009 | RCA DCW615R Wireless/Cable Modem
I don't have cable but in order have the wireless cable do i need to have cable installed first?
Yes you certainly need a cable connection before you can use the wireless capabilities of the cable modem.
Without a cable connection the modem is useless.
Regards.
Sep 30, 2009 | RCA DCW615R Wireless/Cable Modem
How do I lock my RCA DCW615R router?
You Router supports either WEP or WPA Security. First thing to do is enable the security, it will become difficult to enter from other users.
IF your using a default gateway (192.168.x.x) which is your Router Address. You can enter by Internet Explorer to go inside the Firmware of your Router (http://192.168.0.1) then enter.
This is an example of firmware worksheet:
Please rate me.
Thank you.
Sep 04, 2009 | RCA DCW615R Wireless/Cable Modem
Cant use 2 laptops at same time
you need a router to connect 2 pc to one modem at the same time
Jun 15, 2009 | RCA DCW615R Wireless/Cable Modem
The Rca DCW615R
You didn't say who your cable internet provider is, and many (or most, including Comcast) such providers require that the cable modem's MAC address be registered with their network. It's a security feature to prevent unauthorized (read: unpaid) users to access their network. The MAC address is usually found on a sticker at the bottom or rear of your modem. Write it down, then call your cable company's tech support the register it. It should work just fine after that.
Aug 09, 2008 | RCA DCW615R Wireless/Cable Modem
How is it working?
mormally it should work fine
Mar 29, 2008 | RCA DCW615R Wireless/Cable Modem
802.11g upgrade
You can have comcast allow you to log in using the new firmware at 192.168.0.1. You will need the user name and password from them. This will alow you into the firmware so you can change settings, including the PCMCIA card.
Sep 07, 2006 | RCA DCW615R Wireless/Cable Modem
RCA DCW615R Wireless/Cable Modem Logo
1,067 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
