Question about Kenmore 60172 Electric Commercial Dryer
Gas to electric conversion.
My old place had gas hookup, new one has electric hookup. Can I convert my Kenmore 70 series gas dryer to electric, and if so, what do I need to do?
  • 1,543 Answers
No, it is not practical to try to convert a gas dryer to electric. Cost of parts alone (not even counting labor) would exceed the cost of a new dryer. Please don't bother rating this, as anything but a FixYa will lower my rating.
Posted on Dec 05, 2008
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Gas but have only electric hookup
Sorry, but there is no conversion from gas to electric. (only natural gas to LP gas or back again) You will have to get an electric dryer or have a gas line run to the dryer.
May 25, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Convert a gas dyrer into a electric dryer?
Sell the dryer and get an electric one. Conversion is not possible. Be advised that electric dryers run on 220 volts and require a special plug. hope this helps!
Jan 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Gas dryer
Hi Mette-q,
Welcome to fixya.com
I'm Huuum,
You said,you have a Kenmore gas dryer mod. 110.95087400 ser. ms0201135 it's a smartheat quiet pak9. Is there anyway I could convert this from natural gas to electric, is there a conversion kit available.
They do have conversion kits for gas to LP.
But I believe that there is no gas to electric.
You must find a gas line from some where in the home and run it to your location, or buy an electric dryer.
Remember that if you can run a gas dryer it will save you 30% on your energy bill over electric and in time pay for the cost of running the gas line to it.
I hope you are not in an electric only house!
How old is the dryer?? Waiting for your response!
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Here is a interesting report that I just read today
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Sep 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 60172 Electric Commercial Dryer Logo
130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
