Question about Philips Magnavox DVD Player MWD200F
Help with Magnavox MWD200F
When I turn on the DVD player open the tray, put a disc in and then close it then the machine just shuts off. Doesn't read the disc at all, any ideas? Thanks,
The lense is proaly gone or mechanism disrupted
Posted on Feb 27, 2007
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
How can I stop a dvd player from reading non-stop with no disc in player---player is not on lock but refuses to open.
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
Aug 16, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a DVD-RW disc that reads Error problem when trying to play on my DVD player...any solutions
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Philips Magnavox DVD Player MWD200F
I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Greetings
CRENDON
Dec 15, 2008 | Philips Magnavox DVD Player MWD200F
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
I Need The region Free to DVD Player Magnavox MWD200F
if you looking for that code thing...
it's Code = 0247
Aug 13, 2008 | Philips Magnavox DVD Player MWD200F
Disc error message-playback feature may not be available on this disc..wrkd fine b4
I had the same error message with my Magnavox MWD200F DVD player. I opened the DVD player and inserted a DVD and found that then DVD never started spinning. Here's how I fixed it. Remove any DVDs in the player then unplug it and flip it over. There should be a slot that is under the DVD tray on the underside of the DVD player. Move the wheel that can be seen through the slot a couple times with a small screw driver. Flip the DVD player back over then plug it in and try to play a DVD.
Aug 11, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Universal remote programing problem
i have a magnovox MWD200F remote and i need to program it to program a DVP642 can you give me instrustions?
Jan 05, 2008 | Philips Magnavox DVD Player MWD200F
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
Philips Magnavox DVD Player MWD200F Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
