Question about Sony KP-53HS20 TV
KEEP FADING TO BRIGHT BLUE SCREEN
My television is about 5 years old and is now not working properly. The screen will be fine as soon as you turn it on but as soon as you leave it on for 5 minutes it starts fading into a bluish color and eventually the whole screen is a very bright blue color and you can't see anything. If I turn it off and leave it for a couple seconds and then turn it back on it will be fine for about 5 more minutes and then the same thing will happen again. Any ideas of what is wrong or how to fix this? Do I have to get a new TV? Any help is greatly appreciated. Amy
  • Amy Webb Feb 12, 2007
    Do you know how much this would cost to get repaired? Is it worth trying to repair it cost wise or is it better to cut my losses and sell it and get another one in your opinion? Can I test this myself or is this something I should let the professionals handle. Thanks for your response.
    Amy
    Sergeant:
  • 308 Answers
I'm about 90% sure it is the blue picture tube developing an intermittent heater to cathode short. I'm surprised the set isn't shutting down shortly after this happens. A service call will tell you for sure as it could also be a bad solder connection causing a similar symptom. My own procedure to check it out would be to GENTLY tap the neck of the suspected picture tube with a screwdriver handle to see if I could get it to come and go (Or get out my CRT tester and measure it with the power off). Obviously by holding the screwdriver blade you don't want to accidently short anything out as there is about 33,000 volts a few inches away from where I would be tapping. Nuff Said.
Posted on Feb 11, 2007
Accoustics solutions 37 inch tv colour fading and changing
Increase the color saturation to fight the fading and decrease brightness slightly. All of these settings are in the menu of the TV.
Jun 07, 2012 | Televison & Video
Blank blue screen
check truner and cable see if broke
Jul 18, 2010 | Toshiba 26HF85 26" TV
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-53HS20 TV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
