Question about Dell Inspiron B130 Notebook
Laptop wont bootup or sticks at the blue screen!!
Dell Inspiron B130
WindowsXP
Last nite it was working just fine, I shut it off normally. this morning when I tried to reboot, Windows will start to boot, ask for the initial login password and once I enter it, it will state 'logging in...' and then it just sits there. The screen goes blank and it sits blue forever. I have let it go for 35 minutes, but it just sits there.
It does however tells me when the battery is disconnected. It does give me a prompt from my antivirus (SpyDoctor).
Could it be the video card? except I am not sure if B130s have a video card or not.
When I run it in safe mode, the screen just shows black. It lets me start in safe mode with a prompt, still doesnt do anything beyond that.
Sometimes, it gives me a prompt for a new hardware install wizard that needs to be installed but the hardware name is 'unknown'.
WHAT SHOULD I DO??????????
Thanks for the posting.
But I went on to the DELL website and downloaded the necessary drivers and was able to fix the issue. The drivers come in a .exe file so I copied them to the laptop via a USB and executed them. I think it was the BIOS drivers that fixed it.
Thanks for the assistance though.
Posted on Dec 09, 2008
Put installation cd in. Boot and when asked at end. Select repair. When dos screen starts, select operating system. The prompt C:/ will apear, type chkdsk /p this will check your partitions and repair. When it finishes you should be able to restart.
Posted on Dec 07, 2008
Problem with Fan - Dell Laptop Inspiron B130 ?
If the fan is dead, then the laptop will shut itself off after a short while to prevent heat damage. It is normal for the fan to spin up when you turn on the laptop and then stop turning. The fan will kick in again when it is needed as heat builds up. The system fan has absolutely nothing to do with the lcd lighting up.......seriously.
If the laptop is running, but the screen goes dark after a few seconds, it sounds more like the backlight on the lcd panel is shot. From what you describe, I assume that your lcd is not 'lit up' at all, but you can see a faint image on the screen. If this is the case, then either the inverter board is shot, or the backlight for the lcd panel is dead. You can try calling Dell at 1-800-www-dell and try to purchase an inverter board. They are cheap, and it would be worth the gamble to buy one, because if the backlight is shot, then you need a new lcd panel - $350+ (the backlight is part of it and not replaceable). The inverter board is located at the bottom of the display module, right behind the dell logo at the bottom of the display. It's quite easy to get at.
Here's a good test. Shut the laptop off, and attach a computer monitor to the 15 pin vga connector at the left side of the laptop. Turn on the laptop and the monitor should show you an image. If not, try holding the blue 'fn' key and press and release the f8 key. This should switch you over to the external monitor. If the laptop works fine when connected to an external monitor but has no image, then it's definitely not the fan, and you should try an inverter board. If still no good with a new inverter board, you can still use the laptop with an external monitor.
Hope this helps!.......let me know how you make out.
Dec 12, 2009 | Dell Inspiron B130 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
Restore dell inspiron b130 to factory settings
restart the laptop... as soon as you see the big blue DELL screen hold ctrl and press F11.
if done right, this should bring up the dell restore utility, just follow the prompts. takes maybe 15 minutes.
Mar 13, 2009 | Dell Inspiron B130 Notebook
I have a inspiron B130 and it wont boot i just disk rom installed.... now i try to boot from disk rom and it doesnt allow me to do anything it just restarted comes to a blue screen and restart
when computer comes up just after the dell screen hit the f12 key along the top. It will give you the option of booting from cd or hard drive. Pick the cd and if your cd is bootable it should boot from it.If it still gives you blue screen you probably have bad memory.
Mar 12, 2009 | Dell Inspiron B130 Notebook
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
Dell B130 Blue screen error
you need to reload/restore your Operating system
Feb 03, 2009 | Dell Inspiron B130 Notebook
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
Dell B130 Laptop Boot Problem
if battery is new and functioning properly(battery) please boot in safe mode by pressing F8 during os starup. and logon as an administrator.
if nothing works out try reinstalling operating system it will solve the problem else update me the ststus.
Feb 26, 2008 | Dell Inspiron B130 Notebook
Blue Screen with error messages
Startup your laptop keep clicking f8 until you see option like star in safe mode just click on "LAST KNOWN GOOD CONFIGURATION(your most recent settings that worked)"
Simple as that ;-).
Dec 29, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
109 people viewed this question
Alun Cox
