We have a Sharp copier AR-M205, and it keeps giving us the U2 code and we have tried to reset it and it doesn't work.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
U2 code .just check what is the sub code by pessing start key.if sub code is 01 thats counter sum check(memory problem)if 04 eeprom problem if 40 crumic.to reset u2 just do this.press clear ,exposure,clear,exposure,16,print.code will remove .by mian jee
Posted on Dec 17, 2008
In the code "pound star clear star sim 14" what key is sim?
To enter service mode on the AR-M205 you need to press the keys: # key, interrupt key, C key, interrupt key.
then enter 14 & press start.
I assume you are trying to reset an error code.
If you have an error code U2 then enter 16 & press start.
Hope this helps.
Dave.
Oct 13, 2017 | Sharp Office Equipment & Supplies
I want sulving this problem call for service. code : u2-40
Here is a list you can find a copy of all the error codes
http://businessneedz.com/Info/?p=282
Seems like a board error. The machines are almost 12 years old now and parts are very hard to come by. You may be able to pick up a used Sharp AR-M205 off ebay or you may want to consider upgrading to a newer machine.
Sharp Copiers
Nov 06, 2012 | Sharp AR-M205 Copier
Sharp m205 error u2 Problem, what does mean?
press 0 U2 if 04 occurs EEPROM read/write error (serial communicationerror) if 11 occurs Counter check sum error (EEPROM) if 12 occurs Adjustment value check sum error (EEPROM) if 40 occurs CRUM chip communication error
Jan 11, 2011 | Sharp AR-M205 Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
Printer displaying an error message: 2U
There is a long list here for the U2 code so if you let me know I will tell you what it means..
Again what is the Last part of the Code?
If it is U2-40 code, it is a Crum Chip, Take the toner out clean the end of the toner cartridge, there is a chip, a small plastic connection piece with bronze/silver wire on it.
Or replace the toner cartridge.
You will also need to clear the code with simulation 16.
Turning the machine off might work but, not usually.
Oct 28, 2008 | Sharp AR-M205 Copier
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
99 people viewed this question
jasbo
jasbo
