Question about Audiovox PVS33116 Player
Won't turn on
I bought this player earlier this year and it has worked fine with no problems until now. It last worked, for sure, as of this last Sunday. Now, I flip the on/off switch and nothing happens. I did not get it wet, take it outside, drop it, kick it, or anything ... it just sat on the shelf untouched until I tried to use it the next night and hasn't worked since.
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Wouldn't turn engine over
check battery, for correct charge level,are you getting gas ,how about fire to the spark plugs?
I don't know about that year,(to new),but 1988,and some later models
have a module in the distributor that sometimes goes out ,and are heat sensitive if this is the problem you won't
get fire to the plugs untill you change it BEWARE!!!,
the last one i bought,i think was about $64.00
that has been a while so make sure before you run out and buy one!
I hope this helps
Dec 11, 2011 | 1995 GMC Safari
Hi. I recently bought a Sony CDP-CX355. Until a few days ago it was working fine. Suddenly, the player stopped reading the discs. It grabs a disc as if its going to play it, but just reads it, and then...
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Aug 14, 2010 | Sony Audio Players & Recorders
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
System Error
FYI...the best suggestion I've seen is to hold the channel up and play buttons simutaneously....thereby causing the machine to return to the "factory initialized" state. So far so good for me. We'll see. photog1
Apr 22, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Audiovox PVS33116 Player Logo
19 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
