Circuit breaker won't reset - Heating & Cooling
  • janine_carri Dec 05, 2008
    I fixed it myself. I asked a friend who advised me that you have to sometimes WAIT 15 or 20 minutes before turning the switch to the on position.
    nobody mentioned that to me.
  • 1,420 Answers
Disconnect the black wire and try to reset it. Either the circuit has a short in it or the breaker is bad. At any rate, get it checked out by a licensed electrician.
Posted on Dec 05, 2008
I was vacuuming turned off won' come back on
Well, Is it a canister vacuum or does it use bags?
Did it turn the circuit breaker off?
If so, reset circuit breaker and try to turn it back on.
Jun 01, 2017 | Vacuums
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
Bryant breaker panel Main breaker won't reset
Is the handle freely going back and forth, not having
any resistance when you move it?
Jul 13, 2012 | Electrical Supplies
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
THere is no electricity in the bedrooms and I can't get them back on?
If the circuit breaker will not reset - all the way off and then back on with a click sound. Then something you have plugged into the outlets in those rooms is probably shorted causing an over current condition. If the circuit breaker won't reset, shut off all lights and then unplug EVERYTHING and then see if it will reset. If it does, then replug everything one at a time until the electricity goes off again, that is the bad apple.But if it won't reset, then your breaker is probably bad. Yes, they do go bad, just infrequently.
Jan 11, 2012 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
I have two cardio zone treadmills which won't start. console lights but nothing happens. checked the two fuses for continuity, both good. what else can i check? s/n 35005624 and 35005616
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Sep 13, 2011 | Cardiozone Exercise & Fitness
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
My Paloma tankless water heater stopped working after we had a block out, all the lights are working and doubled checked the electrical connector.... it just won't turn on as it should when I run the...
Try reseting it by unplugging it. Also is there any display lights on (troubles). If that dont work it might have fried the circuit board in the black out.
May 09, 2011 | Heating & Cooling
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Heating & Cooling Logo
535 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
