Question about Brother IntelliFax-2820 Laser Fax
Toner life end
I put a new toner cartridge in on Tuesday and worked fine yesterday got an error message saying toner life end what do I need to do.
Sara
  • 1 more comment
  • DocViking Dec 06, 2008
    I have replaced the toner cartridge and I continue to receive the message "Toner life end....replace with new cartridge.
  • Anonymous Dec 09, 2008
    can't seem to find clear botton?
  • bhuggins Dec 17, 2008
    same message, and also can not find any button that says "clear"
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Posted on Jan 02, 2009
    Genius:
  • 2,120 Answers
Open the toner door and hold down the clear button.
Posted on Dec 07, 2008
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Jan 04, 2010 | Brother DCP-7040 Laser Printer
It says toner life end and it prints just fine
The toner life end message means the toner is getting low. It will continue to print without any problem. Eventually you will see the print starting to get light in spots. If it is a new cartridge, the toner level sensors are probably dirty.
Oct 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
595 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
