Question about HP Business InkJet 2800 Printer
Printerhead need replacing
On my hp inkjet business 2800 the machine ask for printerhead replacement for the three colours cym.Now I have replaced them and the printer still asks for new printheads.I've cleaned the contacts on the carriage and on the printheads.Also reset the machine to factory default when the printer was ready at one time but when I started to print a config page,the machine then ask for same printheads to be replaced.
Any suggestion to resolved this would be appreicated.
  • mary63672004
    mary63672004 Feb 10, 2014
    Thanks for the advise, but because I'm not a teckie, I think I'll invest in a new printer. The work involved in trying to figure out the problem and it's solution just isn't worth the work!
Printheads are very sensitive and HP sets a "Time" limit of about two years for # 11 printheads regardless of how much you print. ( This is bunk from HP of course!.) But the prinheads do not expire!! They just show their health and that the printhead has exceeded the warraty period ( regardless of how much you print) .
Remove the printheads from their socket and fill a 8- 12" dish with 1/4" high of warm water. Set the printheads in the water in the same position they are set in the printer (vertical) You may need to place a wooden spoon of a block behind the printheads to keep the heads in position, as they will tilt backwards.
Leave the printheads to soak for about 15minutes.
Remove the printheads and slightly press them on a folded kitchen paper towel .It should show two lines of the same color of the printhead (cyan, yellow, etc) If the two lines are not of the same length (about 1/2" long) then repeat the soaking for that color. Be sure to dry the printheads properly
Install the printheads in the printer socket vertically so the contacts are properly set.. If not you may get a message to "Install (color) printhead". reset it again and run at least 15 pages with color information. It should print ok!!
If any print heads is damaged then the only option is to replace it with a new one.
It may be that the ink line from the cartridge to the printhead is clogged and ink is not flowing. This may require to run a large print job of about 50 or so pages to force ink into the clean printheads.
The terminal strip behind the printhead that makes contact with the pins in the printer are very delicate and if removed two to three times may not make a good contact and render the printhead unuseable.
Good Luck!!
Posted on Jan 10, 2009
  • 87 Answers
Did you replace the printheads with current un-expired new printheads? You may want to check this before doing anything else. If unexpired then you are probably looking at a carriage replacement which is something we can do. We also have these machines in stock.
Posted on Dec 05, 2008
Inkjet 2800 firmware
Setup & Install for HP Business Inkjet 2800 Printer series:
Apr 19, 2014 | HP Business InkJet 2800 Printer
Good morning,
unfortunately we had the same problem in our workshop and we had to replace the motor as a brushless motor is worn and you have the reference here PartSurfer hp:
Apr 22, 2012 | HP Business InkJet 2800 Printer
The majenta comes out pink instead of read.
Magenta is a pink colour.
Try replacing your yellow cartridge.
Red is made up of magenta and yellow being mixed together.
Jun 21, 2010 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 firmware PMR2006A
Unfortunately the page you are trying to reach is not a valid page. As an HP tech I searched internal for a firmware update on that model and there isnt one available.
Jun 05, 2010 | HP Business InkJet 2800 Printer
Asking to replace new printheads
is it laser or inkjet, and cartridges are original ones or compatible ones, some printers will not accept comptible cartridges.
May 03, 2010 | HP Business InkJet 2800 Printer
Business InkJet 2800 just displays rows of asterisks,never boots.
it may want to replace the formatter board, call your HP repair center
Mar 22, 2010 | HP Business InkJet 2800 Printer
Hp business inkjet 2800 will not print cyan although have replaced cartridge and run all onboard diagnostics. hp troubleshoot shows no problem yet printer will not print
You say you replaced the cartridge but did you replace the print head. If you fully lift the cartridge cover you will see a row of print heads. The Cyan print head is C4811A. Try replacing this.
If you feel lucky you can run the print head cleaner diagnostics. The print head may simply be dirty or clogged.
Apr 04, 2009 | HP Business InkJet 2800 Printer
Printer needs all cartridges for black.
Load the empty slots with cleaning cartridges and set the printer to greyscale.
Feb 23, 2009 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 - A3 Problem
Separate the Tray 2, on tray2, u would c couple of while rollers.. check how do they roll and clean for any dust.. While rolling if u feel any friction or any of the rollers broken.., then u need to replace tray 2.
Jul 15, 2008 | HP Business InkJet 2800 Printer
HP Inkjet CP 1700 Inop
The digital readout on the CP1700 is a problem. I have replaced mine now 4 times at a cost of $90 each time, and I'm going to have to do it again or get the new 2800. Just wonder if the 2800 is going to have the same defect.
Jul 14, 2008 | HP cp1700 Color Inkjet Printer
HP Business InkJet 2800 Printer Logo
1,480 people viewed this question
Ben Johnson
