I AM AFTER A CRT W56ECK001XO4 PHILIPS TELEVISION TUBE CAN YOU HELP?
  • 19,396 Answers
Posted on Dec 05, 2008
The picture tube is going bad..do you still make parts for this tv?
Parts for that model have been discontinued for several years now. But you may be able to get a used CRT ( Picture Tube) from www.tvrepairworld.com
Aug 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
I have a Philips 50P8341A and when I turn it on the whole screen is red. Someone said that the tube might be bad. Could that be it? Is it worth fixing?
Yes that sounds like a bad picture tube ( CRT) you can get a replacement CRT at the following link which comes with instructions on how to remove and install the Tube.
http://servicemanuals.vstore.ca/
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
My philips tv is to bright and too red
Your red CRT Tube is failing, ~ the Conrtol Voltage setting is wrong, It can be Adjusted But for how long!?, As the control unit may also be Bad.
Jul 07, 2009 | Philips 64P8341 64" Rear Projection...
TV WENT BLACK WITH BUZZING/SOUND
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
Red crt tube
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Oct 01, 2008 | Philips 60PP9202 60" Rear Projection...
Where to buy CRT TV Philips tube ?
Picture tube will not cause NO color problem, color circuitry problem.
Jul 18, 2008 | Televison & Video
How to replace the crt on a phillips rear projection tv
No trick... It's a difficult task for most techs. On a scale between 1 - 10 and 10 being the most difficult you have a 10.5 there and the fun is just beginning..
Nov 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue Convergence Problem
see if the leads from the green crt Pcb on the green crt is long enough to reach the blue crt. If you hook up the working green circuit to the blue tube and it still dosent light up On the screen, then you know the tube is bad. Just a quick way to test crt's,. If it does light up then you have to trouble shoot the matrix for the blue tube. The drive maynot be vorrct the g2 voltage maybe not enough so then the screen block could be bad. I just wanna warn you against the very very high voltage inside these sets even when there not plugged in. BE CAREFULL PLEASE
Jun 13, 2006 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
