Question about StarTech.com StarView SV211K 2-port KVM Switch
Digivox can you tell me how to change my digivox box from menu screen to to cas system please
  • Anonymous Dec 20, 2008
    singal has been blocked
  • gill gilchrist
    gill gilchrist May 11, 2010
    WHATS CAS? YOU WANT TO CHANGE MENU TO WAT SCREEN? THE SCREEN TO ENTER CODES?FREQUENCY?CAN YOU EXPLAIN I NO ALOT BOUT THESE BOXES
My DIGIVOX has crashed and i have no idea how to put the necessary codes into the computer
Posted on Dec 05, 2008
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and
the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
• While holding these keys press [on].
Please Note: For TI-Nspire Family handheld units that
contain rechargeable batteries you can alternatively hold the above
keys while pressing the [reset] button on the back of the handheld rather than
removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu
with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit
restarts.
• 2: Delete Operating System - The operating system will be deleted
without deleting any documents on the system.
• 3: Delete Document Folder
Contents - This will delete the user's documents, but will not delete the OS.
Selecting this option is the same as using the RESET hole on the back of the
unit.
• 4: Complete Format - This will delete the OS and all documents for a
total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
Mike W. Can't get into the cas system menu on my
virgin have found a way to block boxes but it aint ready yet so dont listen to idiots spreading nagra panik i enterd these codes and my box super works fine here are the codes
00-B0,B8,4F04,E6,5F,87,80
01-A3,EB,EC,07,D6,49,D2,EB
Mar 31, 2010 | StarTech.com StarView SV211K 2-port KVM...
Didgivox cant get into secret menu
Its easy press the menu button, the scroll down to system information press ok till the system data comes up, then press 1004 while you are keying in 1004 the will be no signs to say your entering it, but when you press 4 the menu will pop up read what i just wrote carefully an it should work if it doesn't then something is up i got a digivox xl black Good luck.
Sep 15, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Telewest codes for digivox 17/08/2009
AA B7 D1 D9 CE 8E 83 AF
8E 80 D7 EF 44 93 02 2B
Aug 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
I own 2 digivox t. the pin code to access the cas menu 1004 works
the code for digi t is 1570 other than that all other codes are default oooo
Apr 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ireland Codes for ntl/chorus mmds for digivox T
picture but no sound (irish and virgin channels only) on my digivox-t digital receiver, any solutions
Mar 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do i get in to menu on digivox to install codes
go to remote, press menu
key in code 1004
provider id 5401
00
change keys to - b0 b8 4f 04 e6 5f 87 80
press ok button (on remote)
press exit
Dec 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
Digivox DV3 cable box
You need to Enable the Emulator as this is what clears scrambled channels. Main Menu -Factory Settings enter code 1570 which should give you a new CAS menu. Go down to EMU and switch it on with >vol key. Go up to Negravision and select your area providerer and press OK. Exit and scroll down to Default and hit OK. Will flash "Saving". Exit all the way out.
With certain channels when you first switch to them they may take a minute to upload data automatically.
Good Luck.. Tom (Dublin)
If unsuccessful it is because the code above does not work on your Box. You will know straight away when you enter it if the CAS menu doesnt appear
Jul 08, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
101 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
