Question about Sony Cyber-Shot DSC-F828 Digital Camera
Pictures appear with vertical or horizontal lines, very white
In the "M" (green auto camera icon) mode, can take pics inside with no problem using flash. when in direct sunlight, on "Auto" (green auto camera icon) mode takes pictures at are either too white, have lines (horiz or vert) and just come out real bad. Have tried "reset" but nothing improves
I have had this camera since 2003. Bought brand new in MO, USA. First thing was that the camera/lens hinge became loose. I am on contract in South America. Took it to local SONY service and came back appearing with the problem above.
Have tried to take it back to them for a soultion but get the answer "since not bought from SONY Argentina we cant touch it"
Question: if the problem mentioned above was not there before I took it to them and only APPEARED AFTER I had the hinge "adjusted" why do these d**s now say they cannot resolve the problem that they obviously caused? Why did they take the camera in the first place?
DOUBLE STANDARDS!!!.
SONY after service SUCKS. I now am in a South American country without a camera/no service from SONY, and a big investment in a once damn good camera after SONY Argentina got their hands on it.
They have washed their hands after screwing up my camera.
  • akwaheed Jan 28, 2009
    I have the same problem, n this appeared also after repairing the hinge. I have checked the cables but those are plugged in properly. I took it to sony service center they said the main power board need to be replaced and will cost $300. this it rediculas.
  • Anonymous Feb 03, 2009
    Same problem here. Initially it only happened when zooming 2.5x and greater. Now it just happens all the time.
  • 10,594 Answers
In my opinion, it is just matter of 2 ribbon wires that are not plugged properly at lens section, coming from main board (LCD section) because to fix / tight a loosed Hinge screws, above said 2 ribbon wires (flexible boards) need to be remove on lens side.
Posted on Dec 05, 2008
White blurring and horizontal white lines problem. factory reset?? how to .
Check the settings. Could be you are on manual, or in night mode. Try to put the camera in automatic mode. (green camera loge on the main dial)
May 05, 2014 | Samsung ST45 Digital Camera
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Horizontal lines in pictures
hi If u find that the lines are vertical that is often a result of taking pictures of very bright subjects. This is  called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician , and they will send it out to have it looked at. hope this helps!
thank u rate me!!!
Feb 12, 2009 | Olympus FE-190 Digital Camera
Lines appear on photo's.
Hey Tia Cindy,
If the lines are vertical that is often a result of taking pictures of very bright subjects. This is aberration is called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician such as bringing it to a Geek Squad® precinct in a Best Buy™ store, and they will send it out to have it looked at. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Olympus FE-190 Digital Camera
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Hoizontal lines in images
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Sep 11, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Looks like over exposure
Sounds like your camera is in manual mode. Manual mode is where you can change the settings like shutter speed, ISO, the appature size. If the appature is to wide (small number) and the shutter speed is to slow (low number like 1/20) you will have an over exsposed picture. You probobly need to put the camera back into auto mode. You may have switched the modes on accedent. The modes usualy say Auto, Macro, Manual, and movie. These are all the presets or the camera modes on your camera. If the camera is set right it will take good pictures inside but be white or over exsposed when taking any outside. Go into the menu and scroll over to the little red camera icon. See if its in manual or auto. Another thing to check is "EV" if its at +6 set it to 0 and try it if you cant find auto mode. S
Apr 17, 2006 | Fuji FinePix A205 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
197 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
