Question about Intel D102GGC2 Motherboard
Heating problem my board(intel D102GGC2)hanging because of heating problem it dose'nt support 1gb ddr2 ram, after using pc 1 or 1.5 hour it get hang
i am having 1GB Ram in Single slot,when I add another 1GB ram in the other slot the memory shows only 896Mb.The processer is dual core.
Posted on Dec 05, 2008
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Will 2gb ddr2 800mhz ram support d102ggc2
No. The maximum system memory that can be installed in 2GB, that being two 1GB RAM modules, Also the board only support DDR2 400 or DDR2 533 RAM.
Jan 07, 2012 | Intel D102GGC2 Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
Non-ECC DIMMs
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
