Question about Whirlpool GHW9100L Front Load Washer
Won't Rinse Replaced some parts...after putting everything back together we put the rinse/spin cycle on, it doesn't rinse...no water goes into the tub.
  • jsbovino Dec 22, 2008
    The washer doesn't finish cycle, and I'm getting F02 error code
Had this same problem with my GE WBVH6240 Front Load Washer which we have had for about 5 years. After performing surgery on it; cleaning out the drain hoses, cleaning out the filter several times, checking the operation of the pump, checking the water pressure coming in to the washer, finally narrowed it down to the water valve. Ordered a new valve through Appliance Parts Pros. Got it in 2 days through regular shipping, installed it in less than 10 min, ran it through a quick wash cycle and everything works 4.0. Don't know which parts you replaced but this fix which I eventually got to only cost $50. Saved me hundreds and/or the possibility of buying a brand new washer. Hope this helps.
Posted on May 30, 2010
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Washer will not rinse on any cycle
Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessingthemobilian_3073.jpg
Oct 26, 2011 | Kenmore 23822 Top Load Washer
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Whirlpool GHW9100L Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
