Question about Compaq Computers & Internet
Continuously beeping compaq 1000va ups beeps as if it is on battery even when there is utility power
  • Gav Shaw May 11, 2010
    How long do the Beeps last? and are do they have the same length pause in between them or does it differ?\
    IE - Beep Pause Beep Pause Beep Pause
    or
    Beep Pause Beep Beep Pause Beep.
  • 189 Answers
Was the ups charge? If it was not charge, have charge for a couple of hours means that with no computer attached or computer off.
If still continues have a new battery.
Thanks
Posted on Dec 06, 2008
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
I installed a new battery and then system starts beeping continuously
Hi Anthony,
Is the UPS plugged in? Are there any lit LEDs on the front of the UPS? Did you replace the batteries in while the UPS was plugged in? Make sure that the battery you placed into the UPS is a good battery.
Hope this helps. If you would like more assistance please give me a call: 407.380.9200.
Oct 25, 2013 | APC Smart-UPS 1000VA UPS System
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
Your ram/ram slot may have gone bad, contact Compaq Tech support for detailed instructions.
For a basic idea of what to do if you know what your doing:
1. Pull out 1 ram card in the first slot
2. Start up system
3. If beeping appears leave that slot empty
4. continue until beeping stops
Side Note:
If you keep removing all the ram cards and the beeping continues, I probably got the wrong error.
Mar 01, 2011 | Computers & Internet
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
When the computer is off or sleep it start the beeps!! Ultra 1000va ups
Do you have a battery backup?Sounds like that's what's beeping.
Mar 03, 2010 | Ultra (ULT31502) UPS System
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Getting red light and continuously beep sound to my UPS(Frontech)
hi
If it is showing the red light and continuous beep it shows that the battery is completely gone.
You can buy a battery and replace it by yourself.
Or get it to a professional to change the battery.
you need not replace the whole UPS its just a battery problem.
Thank you
Aug 10, 2009 | Compaq R1500 ( 295459-001 ) UPS...
Problem
DC-DC board or motherboard. does it boot up from a charged battery (like from another laptop)?
if it works on battery power then i'd look to replace the DC-DC board (its a little board inside the laptop that holds the power jack and a few power-related components)
if it continues to beep even when only on a battery then you should look into a replacement motherboard. and if you have a Compaq V2000, i'd look into a "parts/repair" laptop from eBay or something because that will cost less then just a motherboard.
also the DC-DC board may be built into the motherboard. in that case there is none and the motherboard is the thing you want to replace.
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
849 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
