Question about Logitech 961462-0403 Webcam
My hard drive do not recognize the usb wen i plug in
I have done driver
I took my tower apart and cleaned it out (DUST) AND PUT IT BACK TOGETHER NOW ITS WORKING
Posted on Dec 09, 2008
SOFWARE SAMSUNG DRIVER FOR HX-MU032DC
Your computer should recognize the drive when it's plugged into the USB port. There is no driver . If the PC can't find and assign a drive letter to it then look at a bad wire between the hard drive and the USB port.
Jul 16, 2014 | Samsung G2 Portable External HX-MU032DC/...
My computor doesnt recognize the hard drive when plugged in
I assume the computer recognizes a mass storage device on USB is plugged in and appropriate drivers are loaded. Try on a different computer with appropriate drivers, restart existing computer and plug it in after computer starts. If still fails dismantle device and remove hard disk and try directly in another enclosure. Cannot provide further info without more information.
Jan 15, 2011 | Iomega Computers & Internet
Window did not recognized my kingston usb (DT slim)
Usually all flash drive are plug and play devices if your computer is not recognizing it you should try plugging it into another USB port and even try plug in another computer to see if it would work.If your flash drive does not work this mean it is dead and the flash drives are not design to get the information off when it is dead.
Aug 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer doesn't recognize the SimpleDrive...
Hello jajogeglez,
You may need to use another USB device, be it another flash drive to narrow down if it's just your Simpledrive that's causing this.
You can also update the USB devices under your Device Manger using the CD driver for your motherboard.
Hope this helps.
Nov 20, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
USB recognizes it, but not the OS. I get no drive
Hello, nkhamo
Now, when you say USB recognizes it, do you mean you see the drivers being installed? Because if you are the OS is recognizing something has been plugged in.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the os you have. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, reconnecting the hard drive via USB Port.
Good luck, jasahasch
Aug 13, 2009 | Western Digital My Book Home Edition 500...
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
-BIRDMAN - BIRD ^v^
Oct 02, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Logitech 961462-0403 Webcam Logo
23 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
