Minolta ep5000 cspro
I just changed the toner and get an error code c0070 and to request a technician
  • 1,326 Answers
What you need to do is to take the new toner out bottle out and close the front door and let the copier come to ready again and then try to reinstall the toner bottle again and run the copier... Basicly, the toner bottle was put in wrong and you have to let the hopper go back to home postion and then reistall the toner bottle
Posted on Dec 05, 2008
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Code d'erreur C0F10 de photocopie Minolta cspro ep5000
Remove the Large glass below it you will see a pulley in the middle to the right of the pulley you will see a lens assy. off to the right of the lens assy. (looking from the left side of the copier) near the front side of the lens assy. is a small sensor the monitors the Exposure lamp. that sensor is causing that code. Open close front door to reset. if it comes back replace the sensor will be hard to fine due to the copier is a legacy machine from Minolta now Konica Minolta. try link below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 10, 2014 | Minolta EP4000/5000 CS/PRO Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Sep 29, 2010 | Minolta Office Equipment & Supplies
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Minolta EP5000 cspro
Automatic Image Density Control sensor error.Please clean the sensor under OPC drum,press the reset switch after open the front door.Enter into service mode (press STOP-0-STOP-1) select F code history ,open and close the front door,press menu,press reset twice.
Jun 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Jan 24, 2009 | Office Equipment & Supplies
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
170 people viewed this question
k24674
jasbo
jasbo
