Question about Photography
Sticking button I put some batteries in my camera that hasn't been used for a while, then pressed the button which advanced the winder from the ''S'' position to the first frame but then it jammed.I opened the back and put in a film then closed it which retuned the counter to ''S'' but on pressing the button nothing happens.The batteries are new, and when you look through the veiwfinder it is just dark with no images. In the top left hand corner is the number 1000 lit up in green. Is this an expensive fix as I would like to sell the camera and accesories soon. regards pete
  • Bart Pulverman May 11, 2010
    Please let me know the brand and model of your camera, since the solution to this problem is not the same for every camera.
    Scholar:
  • 185 Answers
What kind of camera? If you can move select off auto, the mirror should return to down position. Then if you have a 1/60sec. or flash position fire the shutter a few times before using auto again.
Posted on Dec 07, 2008
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
Film winder jammed halfway throgh a film and i took that film out ( it expired anyway) and i tired to put new one in but i couldnt becuase the film winder wont move do i have to get this repaired?
Check all the batteries. Get fresh ones. If this is a manual, lever-action film advance and you have a camera with a spring-driven shutter you probably have a stripped sprocket and it needs new parts. If you have an electric shutter but there's one spring driven shutter speed as a backup, try that setting. If it is a totally motor driven advance, try checking the drive battery and clean the contacts. If the motor drive is removeable, take it off and try the lever-action advance. Remember, a group of AA cells are only as good as the weakest one. Good luck
Oct 29, 2009 | Photography
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
How to change film in Nikon N 2020
Press the R1 and R2 release buttons. Pull up on winder handle until the back of the camera opens. Continue the pressure on winder handle until you have removed the film canister. Insert new film canister. Pull leader across winder assembly. Close camera back. Press exposure button. Press winder handle in towards camera b
Oct 13, 2009 | Nikon Photography
Sears ks-2/ricoh xr-7 film advance and shutter release problem
You probably need to take the camera in for repair. It sounds like the film transport is not connected to the shutter/mirror cage ***'y.
Jan 26, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
Film advance slipping?
This has happened with my pentax super program. All that was wrong is the the spool/winder was dirty. It needed to be cleaned. You open up the back of the camera. Stick something such as a small screw driver, just something to stop the film winder from turning. Now turn the top of the winder off while keeping the bottom part in place. Be very careful not to close the back of the camera while you do this. Once you have it out give it a clean with a soft cloth and then put it back in. I found it tricky to align it and get it back through the whole. But, that's me. After that it worked perfectly. Until the next time in a year or so it needed to be cleaned again. Hope this helps.
Oct 06, 2007 | Pentax ME Super 35mm SLR Camera
Photography Logo
83 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
