Question about Sony Cyber-Shot DSC-S90 Digital Camera
I have had my DSC-S90 for several years now with minimal issues but all of a sudden it is saying there is a memory stick error C:13:01. I can print my pictures from my memory stick on my printer without problem, but it doesn't work now in my camera.
  • kbaileycgp Dec 27, 2008
    Same issue as Erica.
  • 423 Answers
Hi Erica,
Sorry it took so long for someone to get back to you. What you need to do more often is format your stick in your camera. For some reason, when you take your card...or stick out of a camera, it wacks out the formatting. The camera begins to have a problem reconizing it. So, to fix this, when you put your stick back in your camera after transferring your pics to a computer is format it in the camera using the menu. This should fix your problem.
Rob
Posted on Mar 09, 2009
Will a memory stick pro duo fit a sony cypershot dscs90?
General Specifications & Compatibilitie:
Recording Media : 32MB1 internal Flash Memory, Memory Stick® Media, Memory Stick PRO™ Media, Memory Stick Duo™ Media (with adaptor), Memory Stick PRO Duo™ Media (with adaptor)
Hope this helps.
Jul 01, 2011 | Sony Cyber-Shot DSC-S90 Digital Camera
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 09, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Thanks for using FixYa.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Transfer to memory stick
You should be able to go into the menu for the camera, and select memory card for photo storage. You should also be able to preview the images with the memory card in the camera, and have the ability to copy the pictures from internal memory to the memory card.
Feb 22, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
Dropped camera and i now receive a message "access" i can only view previous shots...help sony cybershot dsc s90
in this condition your optic zoom is out off order & not work properly you cannot remove this problu at home so please go to your nearst sony service centre & fix your problum
Feb 05, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
INSERT ANY NEW MEMORY STICK SHOWING FORMAT ERROR
Please format memory stick by camera Menu >> Format option.
If problem still exist, try another memory stick and check camera again.
Apr 25, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Memory stick error
If it says there is a memory card error it means there is a problem with the memory card or the capacity of the memory card is too much for the camera if u have tried using a diffrent memory card and the camera is compatible with it that says that the camera is defective
Feb 17, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-S90 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
