Question about Senco Finishpro 15 Finish Nailer & Sls15 Staple Gun
Senco finishpro 15.....It worked intermitedly not it will not fire. I had taken it apart and reasembled it and it worked fine, the next day it wouldn't. It is not jambed. When I pull the trigger I hear a little puff of air.
  • 2,176 Answers
When you took it apart did you notice any worn or cut orings? second when reassembling did you lubricate the orings with a light grease? The puff of air might indicate the firing valve in the cap is sticking or possibly you pinched an oring upon reassembly (I have done it also) I would take it apart like before paying close attention to the condition of all the rubber parts. It would probably be to your benefit to purchase an oring kit and just completely redo the insides. They are not that expensive and then you know everything is fine. Also look at cylinder to ensure it is not cracked or out of round and condition of bumper and driver seal in the bottom of tool. Good luck
Posted on Dec 19, 2008
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
Feb 16, 2017 | Senco Air Tools & Compressors
Do i need to buy piston driver assembly or can i by just the driver blade
These new Senco FinishPro tools are chinese made and unlike the old US made tools, you need to buy what's termed a 'piston driver unit'. It should be fairly cheap though, compared to old Senco parts.
Jan 17, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
41xp - leaking air out of top headpsp
You have worn or broke o-rings in your gun. You need Senco Kits number YK0361 Firing Trigger System Kit & YK0362 Piston Stop Kit. If you have it apart, replace all of the o-rings and you'll have a new gun. Remember to replace each o-ring as you take them out so you get them back exactly where they need to go and grease them up well with the lube in the kit.
Jan 10, 2011 | Senco FinishPro 42XP 15 Gauge Finish...
Looking for a diagram or schematic for a senco fp18
I have a SENCO FinishPro18 that I inherited from my son when he died a year ago. It has worked fine till now. It does not shoot a nail when depressed against a board and I pull the trigger. I don't hear air leaking, but it seems there is little pressure. Having taken apart the head, then the base, it all seems in good shape. I have not taken apart the trigger assembly, as the removal is a total commitment. Thoughts? I could use some help.
Oct 24, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
How to load nails into the magazine
Hi. Here are pix that show u what to do. http://www.senco.com/pdf/manuals/us/brad_nailers_11_06.pdf
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Gun will not drive pins flush with wood. Wood is
What is your air pressure setting. A finish nailer such as this usually requires 70 lbs to drive flush. Adjust air to this value and test fire in scrap. Keep adjusting air presure until nail drives flush.
Nov 23, 2009 | Senco 4N0001N Finishpro 11 23 Gauge Micro...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro 15 Finish Nailer & Sls15 Staple Gun Logo
373 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
