Memory card isn't ft
I bought a memory card 2 GB ( 1x2GB) PC26-400 NONECC UNBUFFERED 240 PIN DDR DIMM for my computer Compaq SR5510 P but the slot is not fit ! Can you help me
  • Nicolas
    Nicolas May 11, 2010
    This is the suported memo-sticks for your pc:
  • Dual channel memory architecture
  • Four 240-pin DDR2 DIMM sockets
  • Supported DIMM types:
    • PC2-4200 (533 MHz)
    • PC2-5300 (667 MHz)
    • PC2-6400 (800 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 2GB DDR2 DIMMs
  • Supports up to 4 GB*
  • So the sticks you bought should fit, did you try to reverse them?
    If the still dont fit, go back where you bough them and change to anyone as recomended above.
    Good luck
    President:
  • 2,992 Answers
Compaq's website says that the system will take the memory you bought. If the module will not fit into the socket, it's probably because you are trying to put in backwards. The two sets of contacts are different sizes to make it impossible to put it in the wrong way. Make sure you have the memory facing the right way and it should fit properly. If it still does not, you might have a defective socket. It happens sometimes.
Posted on Dec 05, 2008
    Problem Solver:
  • 11 Answers
The PC26-400 DDR is not compatable to the Compaq SR5510. Check your DDR specifications for your motherboard and purchase the correct RAM.
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Will this ram support my motherboard?
your motherboard supports • Supports DDR2 533/400 DDR SDRAM DIMMs
• Accommodates two unbuffered DIMMs
• Up to 1 GB per DIMM with maximum memory size up to 2 GB
that ram may or may not work, most likely not as the motherboard was designed for slower memory.
Apr 10, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
P4S8X-X motherboard. Latest list of compatable RAM 1.gb
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
  • Chipset: SiS 648
  • Supported DRAM Types: DDR SDRAM only
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Module Types Supported: Unbuffered only
  • Max Unbuffered DDR SDRAM: 3072MB
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 8X
  • Max Component Density: 512Mb
  • USB Support: 2.x Compliant
  • Jul 06, 2008 | ASUS Computers & Internet
    Ram card
    Hi giovanni2,
    Sorry but you're board does not support DDR2 memory.
    Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
    One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
    PC Chips M871G (V1.5) link.
    http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=340&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
    PC Chips M871G (V3.1) link.
    http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=368&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
    If I can help you further, feel free to post.
    Suggestions & comments welcomed.
    Mike
    May 22, 2008 | PC Chips M871G Motherboard
    Whether supports DDR?
    Hi valentin122, you're board does not support PC2700 memory.
    The link below will take you to you're board,
    MSI 845 UltraC (MS 6566). Suggest you add to you're favorites.
    http://www.msicomputer.com/product/p_spec.asp?model=845_Ultra-C
    There is not a bios upgrade to support PC2700 memory.
    Bios link.
    http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=295
    You're manual is here.
    http://global.msi.com.tw/index.php?func=downloadfile&dno=3466&type=manual
    See page 2-5 in you're manual.
    The mainboard provides 2 slots for 184-pin, 2.5V unbuffered DDR DIMM with 4 memory banks. You can install PC1600/PC2100 DDR SDRAM modules on the DDR DIMM slots (DDR 1~2).
    To operate properly, at least one DIMM must be installed.
    Here is a link for you're memory. To reach you max GB, you would need 2 DIMMS.
    http://www.computermemoryoutlet.com/Standard_DIMMs-PC2100_(266MHz)_DDR-184^pin_NON_ECC_(Usually_for_desktops)-memory.htm
    Have more questions, feel free to ask.
    Good Luck!
    Mike
    How to vote you're expert.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
    Apr 12, 2008 | Computers & Internet
    Computers & Internet Logo
    46 people viewed this question
    David Payne
    David Payne
