My HD channels all of a sudden come in like regular TV. What to do? The TV is a week old.
I called the cable company and they had me redo the settings on the TV's remote. Not sure why the settings changed as i only used the cable box remote. Anyhow it's fixed. Thanks
Steve McClain
Posted on Dec 06, 2008
No HD on tv
no it does not, you have regular channels via a box and what is the connection on the set for the HD channels? If from same box do not overlook that the set and box were likely unplugged.
reboot the set and the box both by unplugging for a while and if still no HD reprogram the TV channels which in some modes takes a bit of time--no relation between power board and HD reception.
Jun 02, 2012 | Televison & Video
Looking for hd channel
To get an hd picture you have to use a digital input and this cannot be done by simply turning it to a channel. You need to hook up your HD receiver (box) to your tv using either an HDMI or a Component which will be a cable that looks similar to an rca but there are three of them and the colors are bed blue and green. If there is a red, blue and green on the back of the cable box and the tv hook them together with a component cable and then find the input on your tv that correlates to the compnent connections and then even after all of this you need to be tuned into a channel that is offered in high definition and if you have cable like I do the high definition channel will be a seperate channel from the regular one. Comcast in my area puts the HD's from channels 400-500. For example my espn HD is channel 403 but just regular espn non HD is on channel 27 in my area.
Sep 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
Bought a used lg ru52sz51d
It sounds to me as though your old HDTV has a HD tuner built in. Not all HDTVs do and unfortunately your LG does not (I looked it up).
If you want to get free over the air HD you will need to buy a HD digital tuner box and an HD antenna.
Jan 07, 2009 | LG RU-52SZ61D 52" TV
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Can't advance channels with remote
Hey Guys and Gals I have the solution to your problem. Your channel memory on the remote has been forgotten. Simply navigate through your menu on the remote and rediscover the channels and your issue should be solved. I had the same issue it just took me a little time to figure it out.
BTW if you are hooking up your TV with a direct cable connection in the back without a box, and you go to the menu and do a search for air/cable channels it will even find the channels in between the regular broadcast stations (i.e. between 2 and 3 there is 2.1. which is channel 2 HD and so on for the regular stations that broadcast HD channels). Cheers and good luck the Sharp Aquos is an awesome TV!
Jeff the Sofa King :)
Feb 05, 2008 | Televison & Video
Tv switches source channel without warning
Hi Andy.
What is the samsung model number ?
Dec 31, 2007 | Televison & Video
Pioneer 60"hd plasama wallmount
If you have H/D one of your cables might be loose i would suspect the red one
Oct 22, 2007 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
