EO4 POPS UP ON MY bOSH FRONT LOADER WFMC33O1UC
THE CLOTHS REMAIN WET TOO
I had error code E06 come up on my Bosch Washing machine and since cleaning out the pipe as suggested, turning the machine back on to run a wash, error code E04 has now popped up...please advise asap what's the best thing for me to do...many thanks :)
Posted on Aug 16, 2010
Did not drain. i replaced drain pump still does not drain
Could it be one of the valves? My LG front loader had problems with one of the electronic valves not opening and closing properly.
Dec 09, 2015 | Maytag MAH6700AWW Neptune Front-Load...
My siemens washer front loader is displaying an E04 what does that mean
Drain is blocked - unplug the auxillary drain plug and check for clog.
Mar 21, 2014 | Siemens WXL142 Front Load Washer
Need manual for maytag washing machine model As11
probably needs a belt. pull the washer from the wall and tilt it back against the wall, make sure it is stable. then look under and find the belt and replaced from a local vendor.
Jan 02, 2012 | Maytag VRSCDX Night Rod Special Washing...
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Loud noise when on spin cycle. Kenmore front loader. Cloths still sopping wet
This is a common problem on this machine Your rear bearing is bad and requires outer drum and bearing kit.not worth fixing buy a new machine.hope this helps.please rate my response :)
Dec 09, 2009 | Washing Machines
Front loader
something is restricting the draining of unit either in the drain hose, but most likely in the pump remove the bottom panel and pump is in the middle and have 2 5 gal bucket handy to catch the water when you unscrew the cap to the pump ----- unless you use your wet/dry vac to empty the tub this is the best method then only a small amount of water will remain
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
I have a GE WSX208H FRONT LOADER = WET CLOTHS
Pump you are correct. This company should tell all of us that there is a hidden drain plug that needs to be cleaned out every so often so that we do not burn the pumps up on these front load machines.
Jun 15, 2009 | Washing Machines
Cloths still soking wet after rinse cycle
remove the front panel on the bottom look for a screw out filter bout 2 inches long youll see it screw it out clean the filter and reinstall the filter then the water should flow out on spin good luck
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
467 people viewed this question
Top Washing Machines Experts
