Question about Jeep 10 x 20
Heat comes out driverside/cool air comes out the passenger side?
I turn on my heat in my 2001 jeep grand cherokee limted 4.7 and heat only comes out on the driver side and cool air on the passenger side, i just put on a new blower resistor because it did'nt work at all, not i have this hot and cool problem to deal with. Is there some way i can fix this problem myself????? PLEASE HELP! Thank you....P.S. Could it be that the vents are not closing, and if so how can i fix this myself?
It sounds like your blend doors are broken. As it turns out, this is a VERY common problem with grand cherokees. My father and I fixed this problem on my 2001 Jeep Grand Cherokee Limited 4.7 about 2 months ago using a product called Heater Treater, found here: http://www.heatertreater.net/
You can find a very helpful detailed write-up of the fix/installation here: http://www.jeepsunlimited.com/forums/showthread.php?t=854246
Trust me, this REALLY works and a lot of Jeep Grand Cherokee owners, including myself, have done this. YOU WON'T HAVE TO REMOVE YOUR DASHBOARD, as the repair is done by simply removing your glove box. The downside is that you will lose Dual Climate Control, as the driver side thermostat will now control both sides. For me, it was worth it. Only spending about $150 for a Do-It-Yourself solution, versus spending about $1000 to have a mechanic remove my dashboard to fix it.
Posted on Jan 17, 2009
  • 21 Answers
I agree with the above post i fixed it myself in about an hour its a great product
Posted on Dec 03, 2009
Passenger side not throwing heat
UNDER YOUR DASH THERE IS WHAT IS CALLE ACTUATOR VALVES ONE OF THEM IS ETHERE STOCK OR BAD CHECK DOES OUT IF NOT LET ME KNOW OTHER A VACUM LEAK OK
Nov 18, 2012 | 2000 Jeep Grand Cherokee
JEEP CHEROKEE LE DRIVER SIDE HEAT DOESN'T WORK
If you have heat on the passenger side then this is just a simple case of the hose supplying the heat has com off of the heat exchanger
Aug 26, 2012 | 2001 Jeep Grand Cherokee
01 jeep grand cherokee limit driver side air warm
You have the blend doors problem which needs to be fixed. At jeep it is about £1300, by EDM in bicester it is £255 and maintains dual control. I would imagine the recirc dooe is or soon will go as well.
Oct 22, 2009 | 2001 Jeep Grand Cherokee
2001 jeep heater on passenger side not working
there should be a small valve attached to a hose coming from the engine into the firewall this valve directs the hot engine coolant into the heater radiator in the heater box it probably is closed open it and, you should have heat then: it should be easy to find the reason it was closed
Apr 30, 2009 | 2001 Jeep Grand Cherokee
AIR Problems
try making sure the duct work is ok
Apr 09, 2009 | 2001 Jeep Grand Cherokee
My blower resistor keeps going out, even after i buy a new one..
As the circuit is through this resistor, and the main load is the blower motor, I think this is taking a higher current than normal to make it turn. You could simply fit a lower rating fuse to the circuit - as this is cheaper to replace, and check the fan to make sure it is easy to spin by hand. If not, try and oil the bearings as a last resort before replacing it.
Jan 08, 2009 | 2001 Jeep Grand Cherokee
My heater on my 3.1 td grand cherokee jeep has gone cold?
Something similar happened in my Jeep last winter...except mine was only the driver's side. The passenger side blew hot air when heater was on, but the driver's side blew cold air. The solution for me was to replace something called the 'blend air door'. It fixed the problem but cost me nearly $500.00. Hope this helps...
Jan 05, 2009 | 2001 Jeep Grand Cherokee
Heat works on driver side, passenger side blows cold air.
Did you check your coolant level or was it low and you added to it at some point? If so the system my need to be bleed or worst case the thermostat is going bad.
Jan 02, 2009 | 2001 Jeep Grand Cherokee
2001 Grand Cherokee Heat on one side cold air on the other side?
The blend door on the passenger side has broken. Jeep has made a replacement section for the heater box assembly so you don't have to buy the whole thing. You will need to remove the heater/A/C box to replace the part. I have done quite a few of these repairs to fix the problem
Nov 21, 2008 | 2001 Jeep Grand Cherokee
Jeep grand cherokee heater
Pass. side blend air door motor is probably bad.
Oct 25, 2008 | 2000 Jeep Grand Cherokee
Jeep 10 x 20 Logo
471 people viewed this question
Top Jeep Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Jeep Optic Expert? Answer questions, earn points and help others
