Question about Motorola Mobility RAZR V3
My inside screen on my motorloa k1 has gon white
What do i do ?
  • 2 more comments
  • gsosyo466 Dec 05, 2008
    no light on screen
  • yasmin87 Dec 06, 2008
    white on screen inside and wont work properly
  • LizzleBlizz Dec 06, 2008
    it started just doing it sometimes and now it's been like that for 3 weeks!!
  • Anonymous Dec 06, 2008
    Its just completely black...but the cell phone does turn on!!!!help!!!!!!!!
    Brigadier General:
  • 7,752 Answers
Clarky - replaced the flexcable on the phone......
GUEST - replace either the flexcable or lcd
little - have the lcd replaced
yasmin - replace the lcd
gs - replace the LCD
Posted on Dec 28, 2008
Motokrzr k1 display shows white blank how do i got
Hi there
The problem with your phone is the flex,
The flex is a cord that connects the screen to the phone panel,it is found in all flip and slide phonesthe flex of your phone has either shifted position or is too weak..
Try opening up your phone,you will see a cord that connects the screen to the panel of the phone. try removing it(be very careful) and fix it back in place.
Assemble the phone and put it on to see if works,if it doesnt work then the flex has to be changed for your screen to come up again.
Please if you can do this yourself you should get a person with experience to do it for you
GOODLUCK!
Jul 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Krzr k1 the screen went white and it shut down.( continuesly )
There is a problem with motorola phones .Data cable between screen and main board use to brake by the flip top screens hindge.Hopefully it is not your problem,if it is then only in service they can fix it by replacing this cable.If it is a software problem then you can try to solve it by yourself.It may work if the software is faulty on the phone.Just follow the link below.
http://motohell.com/
Jul 23, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My motorola k1 screen is blank
clarky - the flexcable on the phone needs to be replaced
elo+lilvic+guest - the lcd needs to be replaced on the phone.
Dec 05, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
White Screen
Most problems like that deals with the Flex cable connecting the phones pcb board to the lcd (screen)
The flex cable seemed to be broken so you have to bring your phone to your nearest service center.
Hope it helps
Nov 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
White screen
take the phone and have the lcd replaced on the phone from a mobile service center
Nov 08, 2008 | Motorola Mobility RAZR V3
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motokrzr k1 problem
my phone turns on but the key pads not working do you no how to take the key lock of
Aug 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
KRZR K1 White screen
problem with flex cable(ribon).take it back to the shop
Sep 12, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
