I had an engineer out ot look at it and is the main PCB, so I'm going to talk nicely to Comet. Will keep you all posted. Thanks for all commentsI had an engineer out ot look at it and is the main PCB, so I'm going to talk nicely to Comet. Will keep you all posted. Thanks for all comments
AnonymousMar 19, 2014
my thor ceramic hob will not come on,when you press it to start it all it is showing is the letter L on each circle.my thor ceramic hob will not come on,when you press it to start it all it is showing is the letter L on each circle.
AnonymousMar 22, 2014
my ceramic hob goes on and off frequently(almost every two seconds) with clicks when I use it on. four stoves have the same problem. does any body know the reason or solution?my ceramic hob goes on and off frequently(almost every two seconds) with clicks when I use it on. four stoves have the same problem. does any body know the reason or solution?
AnonymousMar 26, 2014
Instead of going off and on at a slow speed one of the elements is going on and off too fastInstead of going off and on at a slow speed one of the elements is going on and off too fast
You can't post conmments that contain an email address.
i cant find any information on your unit. here should be a tech sheet somewhere in the cooktop. wether its on the bottom or inside with the burners. if your getting the f1 code that will tell you exactly what to do.
The 'H' symbols will flash in the display the first time your hob is connected and switched on. This is because the hob has been heat tested at the factory, then switched off while still hot. This may also happen if you are using the hob and you have a power cut.
Error code F1 indicates that the power is too low due to unsuitable cookware or an empty pot. Error code F indicates that there is no cookware on the zone or the cookware is unsuitable.
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
Touching the key area for more than 10 seconds.
Leaving a wet cloth on the touch key area.
Spilling a liquid on the key area.
By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
no help at all , its only 18 months old and I would cerainly not recomend COMET or CANNON.
Extremely disappointed
c60etc. and according to the sale act comet should pay for it
