Question about Balance CM2015 15" LCD Monitor
No RGB imput signal
My almost new Balance CM2015 monitor is giving the message RGB no input signal. It does recognize when the cable is disconnected.
I checked the cables none are loose. I also tried to hook it up to my lap top to see if it was a problem with the tower/ video card/ motherboard… When I hooked it up to my laptop it worked for 10-20 seconds before it went black and then said “ RGB no input signal” again.
Is there any hope to get this thing to work?
  • Anonymous Feb 16, 2009
    my almost new compac does that it goes on stand by for a bit then when i shake the mouse and press space it comes on but is a black screen with a red outlined box saying rbg no iput sinal and i am getting wound up with it coz i got to press the green button it and do that 2 times to get it only just working and i check the cables (cant find the right pic )
  • ajayjnr Feb 16, 2009
I am having a problem with my LCD Balance Monitor as well. I have both cables for the Monitor hooked up.
Posted on Jun 30, 2011
    President:
  • 1,073 Answers
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Posted on Dec 05, 2008
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
Monitor goes to standby after booting up.( Amber light)
I'm going to guess that your monitor has different imputs and maybe you aren't selecting the right one? There is usualy a button to change imputs on the monitor. If there is no signal and you've checked all the channels, the cable your using might not be functional or your monitor might be broken.
Apr 18, 2010 | HP mx705 17" CRT Monitor
My monitor keeps giving me a no signal message after i turn on my computer
  1. make sure that the video cable is properly connected between the monitor and computer
  2. change the video cable
  3. do a monitor selftest
  • turn off the monitor
  • disconnect it from the power outlet
  • disconnect it from the computer
  • turn on the monitor without the video cable
if you see the monitor information (a box with RGB white colors, the monitor is working)
  • problem might be the cable, video input port of the monitor or the video output port of the computer
Apr 10, 2010 | Acer AL1916W 19" LCD Monitor
No input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
May 02, 2009 | Computers & Internet
I need the display driver cm2015
http://members.driverguide.com/driver/detail.php?driverid=564775
I'm not sure where you found your driver, but this is from another website, hope itworks
Dec 13, 2008 | Balance CM2015 15" LCD Monitor
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
Balance status of my A/C
I have a balance LCD 17" monitor when I turn it on i get a message of RGB NO INPUT SIGNAL!
Dec 11, 2007 | Balance CM2017 17" Monitor
Balance CM2015 15" LCD Monitor Logo
803 people viewed this question
Top Balance Computers & Internet Experts
kenneth njonjo
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
