Question about Whirlpool GSW9800PW Washer
Washer off balance
I had some minor repairs on my washer and now it bounces all over the place. It knocks into the dryer, I even had to take items off my cabinet to keep them from being knocked off onto the floor. My washer needs to be balanced badly. How can I fix it? Thanks..
    Problem Solver:
  • 12 Answers
Check your skate plate assembly or Base pad. these are the leading reason why the machine will be jumping around.
If these are in tack.
Please specify minor repair.
Posted on Dec 24, 2008
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer is loud and noisy it sound like a washer when its out of balance. I would like to know where to locate the belt on it its model number is ned5100tq1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 20, 2011 | Dryers
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Washer shaking very bad
It's very likely your washer is out of balance. The load has shifted and is not evenly spread throughout the tub.
Stop the cycle, open the lid, move the items around so they are more evenly distributed and that should solve the problem.
Oct 27, 2009 | Maytag LSE7806A Top Load Stacked...
The drum spins wildly out of balance to the point that it wears away the hard white plastic shield at the front. Is there some alignment guide that may need to be adjusted
this is usually caused by uneven loads. if your sure the the loads are evenly balanced check under your washer for loose or dropped parts
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Spin Cycle - washer starts bouncing around room even though level
There are about 6 pairs of springs to hold the bottom tube to the bottom chassis. If some of these came off from designed positions, the tube won't be in balance then the washer starts bouncing off. Make sure these pairs of springs in place then you have no problem.
Sep 15, 2009 | Washing Machines
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool GSW9800PW Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
